Assess my PPI compression #s
Hey all,
Getting close to pulling the trigger on an '86 Targa, currently has 130k miles but top end was rebuilt at 100k miles. Had a PPI performed and the following was noted:
Compression Results: 147, 149, 151, 151, 155, 152 (test performed at 3740 feet above sea level)
-Both upper valve covers sweating (valves haven't been adjusted for 9k miles)
-Brake pads: 5MM front and 4MM rear
All I know about compression results is the lowest number should be less than 15% lower than the highest number.
Happy to get any feedback.
Thanks,
Tawheed
Old 08-19-2011, 05:22 PM
Compression numbers look like numbers you can live with. All in the same group. If the oil pressure is good, should be solid.
Bruce
Old 08-19-2011, 05:35 PM
Does the tech performing the compression test remain neutral - as in no opinion?
Surely, he must have said something.
BTW, those numbers sound fine to me. Cranking speed will have an effect on pure numbers, but it's important to have consistent figures.
Sherwood
Old 08-19-2011, 08:21 PM
He said they were good. Figured I'd throw it out to the boards just to garner additional feedback
Old 08-19-2011, 08:58 PM
