Check Your Fuses ....
I had an odd electrical issue where my alternator light came on when I went into reverse, and when I used my turn signals. The gauges also went dead at the same time, bit not all the time, only occasionally.
Wierd Electrical Issue After I bit of searching I found the issue: A bad fuse contact face. And when I went to replace fuse #12 I barely touched fuse #13 and it fell out. Digging a bit deeper I found the spring tension on several of my fuses was completely gone. I had to remove the loose fuse, bend the spring tab up and re-insert the fuse. You can rotate the fuse with your finger, if it spins too easily then you need to make an adjustment and increase the tension.
"A machine you build yourself is a vote for a different way of life. There are things you have to earn with your hands." |
Mike Holbrook
First thing I did was to replace all the fuses and relays in my car and wire brush the contacts.
I notice that since I fixed the AC that fuse gets pretty hot. I'm going to look for a solution to that.
Mike Holbrook Meridian, ID 1979 911SC Targa |
If you search there are some nice conversions to 'real fuses' using these (Or similar)
Fuse Block, 3AG, 6 Circuit w/ground 5015 - Blue Sea System Fuses and Fuse Holders @ MarineEngine.com
I replaced all but five of my front fuses this year. The kit I bought was short or something.
Yea, some of those tabs needed to be bent up just a tiny bit. Found a couple of fuses no where near the rating they should have been too. Time to do the rear panel, this post just reminded me.
1977 911S Targa 2.7L (CIS) Silver/Black 2012 Infiniti G37X Coupe (AWD) 3.7L Black on Black 1989 modified Scat II HP Hovercraft George, Architect |
Make Bruins Great Again
Make it a part of your maintenance routine to simply rotate each fuse after doing an oil change. This will ensure the contacts are clean and that the fuse is properly seated in the holder.
-------------------------------------- Joe See Porsche run. Run, Porsche, Run: `87 911 Carrera |
Under the radar
I had a problem where the rivets on the back of the fuse panel that serve to connect the fuses together had slight corrosion. This was causing a slight resistance and the heat almost burned up the fuse block. I originally thought it was the fuses, but after replacing them with heaver fuses I realized it was the connections on the back of the fuse block causing the problem. I cleaned the rivet heads and ran a bead of solder over them to fix it.
83 911 Production Cab #10
My first problem when I got the car. One of them was actually broken, not blown, just broken. Joe How is the hokey withdrawal going?
Who Will Live... Will See ![]() ![]() ![]() 83 911 Production Cab #10, Slightly Modified: Unslanted, 3.2, PMO EFI, TECgt, CE 911 CAM Sync / Pulley / Wires, SSI, Dansk Sport 2/2, 17" Euromeister, CKO GT3 Seats, Going SOK Super Charger |
I need therapy. I almost watched baseball yesterday. Painted my house instead.
muck-raker
I recently spent approximately 20 minutes by disconnecting the battery and using a small brass brush to clean every contact on every single fuse block, as well as the metal contact on each and every single fuse.
Now, everything is shining like a diamond in a goat's arse.
STONE '88 Cabriolet, using EP Slick 20w50 partial synthetic Snake Oil...just as Rommel intended. ![]() Deny Everything; Admit Nothing; and Always Make Counter-accusations
RETIRED
My electric windows decided to die on me today.....spun the fuse they came back. Welcome back to CA and salt air.
Baseball is slower than watching paint dry.
In the never-ending quest to find other things to spend money on (WRT the 911), has anyone converted the installed fuse block to the more modern blade fuse system? For some reason, this seems like a conversion that would mitigate some of the corrosion we see with these cars. Just wondering. . .
Don Newton “People sleep peaceably in their beds at night,” George Orwell wrote, “only because rough men stand ready to do violence on their behalf.” "I gave up visiting my psychoanalyst because he was meddling too much in my private life." Tennessee Williams |
RETIRED
Holy Jesus. I just thought about this when reading this thread. Maybe I should spend more time on this site.
John W
+1 to kidrock use small metal brush to get them good and shiny - steel wool will also do great but you got to catch all the debris. then make sure they have good tension.
----------------------------------- John 89 3.2 Targa 123k miles |
'81 924 , '85 944 , '78 911SC , '82 928 5.0L "They run best being run close to the ‘limit’ and done so regularly" - Grady |
muck-raker
UnRegistered User
You can clean the contact tabs with the eraser on the end of a pencil. Does a great job, just give it a spin.
Bill K. "I started out with nothin and I still got most of it left...." 83 911 SC Guards Red (now gone) And I sold a bunch of parts I hadn't installed yet. |
