DME Relay Question? Use O.E. or aftermarket?
I noticed Pelican has the original DME Relay for about $100, and an aftermarket one for about $25. Has anyone had good or bad luck using the aftermarket one? I am just buying one for a backup as it seems to be good insurance on a road trip!
Thanks in advance. |
RETIRED
They are built in various countries...get two if you buy, aftermarket.
1983/3.6, backdate to long hood 2012 ML350 3.0 Turbo Diesel |
buy the best, cry once.
Don't buy the URO one. I have seen them bad right out of the box.
Original owner 1986 944 1987 951 968 wing from CPR, Deutsche Nine headlights, KW Variant 3s, Lindsey Stage 2 intercooler, Big Reds 2003 Ruf 3600S S-Car-Go equal length headers, otherwise almost stock 72 911T w/ SC 3.3SS engine MoTeC Hargett ITBs |
Get a failed genuine porsche one from someone for free. Pop the cover off and reflow the solder joints yourself. Now you have a free working DME relay. The reason they fail is because they get too hot, and the original solder joints crack.
SOLD: '87 Carrera |
muck-raker
+1. URO is Pure Junk. JW's right on the money, there's not too many discount aftermarket parts that work well with these cars, you're better off spending the $$$.
STONE '88 Cabriolet, using EP Slick 20w50 partial synthetic Snake Oil...just as Rommel intended. ![]() Deny Everything; Admit Nothing; and Always Make Counter-accusations
I just picked up a spare DME relay from our host the other day.
Got the $25 one - it's a KAE (I think) made in Germany. |
Mo money = mo parts
The KAE's have been fine for me. Quite frankly, I forgot that Porsche had an OEM unit. At 4X the price, I am good with the KAE one. I carry a spare.
Greg 86 Coupe (stock - pretty much like Butzi designed it) - gone, but not forgotten 65 Ducati Monza 250 & 66 Monza Junior (project) "if you are lucky enough to own a Porsche, you are lucky enough" |
My KAE failed after one year. Fortunately I ordered and received a spare 3 days before it failed. This time, I was able to replace the DME relay in 5 minutes. I now carry two spares - KAE of course...
Scott ___________________________ 1985 Carrera Targa - Guards Red 2006 Acura TSX Navigation - Milano Red |
Recreational User
I just bought one on the Vertex website for $25. It says OEM in the product description, but they sent me a URO. Is URO an OEM supplier?
RETIRED
NO,,,,,
They can't even make a decent rubber hose.
I have two from Porsche. Best way to go.
+1, there.
I've several laying around, as I change this damned thing out preventatively....one day, when bored (I guess), I'm gonna' slap 'em on a power supply and have a static measure of contact(s') voltage drop...(that is 'unloaded but switched"). I recall changing this out one time (years ago) and SWORE the car ran a bit better (could be full of it, too....) Clearly that DME relay is to switch voltage (fuel pump and DME), and do it with minimal loss... As to non-catastrophic failures of this device, I wonder if the contacts become resistive enough (to any serious degree) to drop the voltage to both DME and Fuel Pump? As well, I think I''l disassemble a few and have a look at the materials used to construct it... Best! Doyle
Recording Engineer, Administrator and Entrepeneur Designer of Fine Studios, Tube Amplifier Guru 1989 Porsche 911 Carrera Coupe 25th Anniversary Special Edition Middle Georgia |
