Mikey_VKG's Avatar
Send a message via AIM to Mikey_VKG Send a message via Yahoo to Mikey_VKG
Brake compatibility
I'm having a problem mounting the brakes on my "kit" car. I was told they were 993 calipers. I've been gathering parts from different sources for a couple of years. So I'm not exactly sure I ended up with the right parts. Best I can figure, either the pads are wrong or the disc is wrong.
I've had both the disc and caliper mounted on the car for a couple of years, I just bought the pads and I can't get the disc to fit inside the pads. The pads have about an inch of space and the rotors are an inch and a quarter. Maybe this has something to do with it, but the hubs are not pictured.
Any help will be greatly appreciated. I'm not sure what other information to include or pictures, but I will add more if needed.
Thank you,
Mike
Old 06-22-2011, 04:47 PM
Any part #'s? Almost sounds like you're trying to mount N/A calipers over TT rotors.
There are some caliper/rotor combinations where you need to open up the caliper throats and/or shave the pads to use them (belt sander apparently works well), but that wouldn't be necessary for calipers over the factory rotors they were designed for.
Looking at the photo - are you sure the caliper pistons are all the way back in the bores? Pads - especially the one on the right - look a long way out. The pistons would have come out as the old pads wore down, they may just need to be pushed back in.
As long as they're not seized, should fine to push them apart/back in carefully (e.g. a tire iron with something sacrificial on the piston tops so they don't get chewed up) - but keep an eye on the fluid level so the master cylinder doesn't overflow. BTDT...
'77 S with '78 930 power and a few other things.
Old 06-23-2011, 02:44 PM
Bill Verburg's Avatar
Thank you,
That looks like a 993 caliper, of course there are several variants, but they all want 304-322 x32mm rotors
as Spuggy mentioned it looks as if the pistons are not fully retracted.
Bill Verburg
Old 06-23-2011, 03:04 PM
Mikey_VKG's Avatar
Thanks Spuggy and Bill. You were both 100% spot on. I didn't retract the pistons into the caliper all the way. I guess I jumped the gun a little and didn't put more thought into it. I used a 8" c-clamp to compress the pistons. Worked like a charm. Pushing excess fluid out of the caliper.
I appreciate the help.
Mike
Old 06-23-2011, 05:37 PM
Max Sluiter
Flieger's Avatar
Dare I ask, what is the car?
Old 06-23-2011, 07:22 PM
Mikey_VKG's Avatar
Well, it's a 1964 Vw Karmann-Ghia.
'64 Karmann Ghia body on a '74 chassis.
Body: Dechromed, debadged, widened front and rear fenders, and a front mounted radiator.
Brakes: 993 calipers and rotors, '87 944T front hubs, '86 944T rear hubs and rear caliper brackets.
Transmission: 914 with a 901 nose cone.
Engine: Subaru JDM 2.0T
The front hubs are riding on stock vw bearings with custom bearing spaces and caliper mounts by vdubengineering.com. Also pictured is a 5-bar suspension brace from vdubengineering.com.
A work in progress.
Questions, comments? I welcome both. But it's my first build.
Mike
Old 06-24-2011, 07:47 PM
Max Sluiter
Flieger's Avatar
Interesting.
Old 06-24-2011, 09:23 PM
