E-man930's Avatar
I need some help getting the correct front mount oil cooler
for my 930, I'm planning on using this front bumper and I want the biggest cooler I can fit up front... (tied in series with the stock fender mount cooler)
Bumper ==> www.Rennspd.Com
B&B has several specs listed, can you guys shine some light on this?
I do not plan on cutting into the tub at this time, so keep that in mind when sharing info.
Thanks in advance!
E-man
Old 07-02-2011, 07:03 PM
Danny_Ocean's Avatar
Part of the equation to consider is how much space will you have behind the cooler before you run into the tub. You need enough space behind the cooler for the hot air to flow through vs. reflect back.
I would mount the bumper first, then source a cooler.
Old 07-02-2011, 07:09 PM
E-man930's Avatar
That is a great idea - I was hoping someone had gone down this path before but no sense in waiting as I will need the front and rear bumper anyways. I'll call them up on Tuesday and place the order.
E-man
Old 07-02-2011, 07:10 PM
Originally Posted by E-man930 View Post
I was hoping someone had gone down this path before...
Not to worry...your posting is new. Given more time, I'm almost positive someone will chime in with exactly what you'll need.
Old 07-02-2011, 07:13 PM
rfuerst911sc's Avatar
I will be doing this on my SC in the future. I will probably go with Mocal they are great to deal with. I will mount the front bumper/valance first and take the dimensions then. I don't plan on cutting the tub either.
Old 07-03-2011, 04:16 AM
175K911's Avatar
Those Ruf Yellowbird replica valances don't give much room between the opening and the chassis. I attempted to cram my B&B in there but it was so high up that almost the entire back of the cooler would have been coverd by the chassis sheetmetal. So I got a TRE nose that gave a bigger opening and greater room.
Ed
'86 911 Coupe (endless 3.6 transplant finally done!)
'14 Jeep Grand Cherokee 3.0 Turbodiesel (yes they make one)
'97 BMW 528i (the sensible car, bought new)
'12 Vintage/Millenium 23' v-nose enclosed trailer
Old 07-03-2011, 08:36 AM
Bill Verburg's Avatar
Thanks in advance!
E-man
Rob Fusi aka 'MuffinMan' did a great job outlining his B&B FPOR-9400(Smart Racing #153201) install Here
I installed a slightly smaller smaller B&B(Smart Racing 153202) in that bumper w/o mods
the 153201 is 6x3x24 the 153200 is 2.25x5.5x20
Bill Verburg
Old 07-03-2011, 10:36 AM
Setrab makes a very nice front cooler setup with 2 fans in the back. Might fit depending on your space.
1973 911S (since new) RS MFI specs
1991 C2 Turbo
Old 07-03-2011, 10:52 AM
SCOTITUDE's Avatar
Send a message via AIM to SCOTITUDE
put this in my SC behind a TRE RSR front bumper. no cutting tub. works good, huge drop in temps.
Porsche 911 RS RSR Style Bumper Mount Oil Cooler - NEW | eBay
1980 911SC #99 track car, 993 3.6, 50 PMO's
2019 Ford F150 da dragger
2015 MB SL400 wifey DD
2008 E93 M3 DD
2007 E60 530 wifey winter beater
Old 07-03-2011, 02:59 PM
Yup, agree.
PO fitted an RX7 cooler behind that very same Rennspeed Ruf bumper cap (except for a narrow body car).
He did modify the tub behind the cooler a few (couple?) inches to allow for better air flow through it, but it doesn't look like it was necessary to mount it. Cooling performance is impressive; never seen oil temps over 210-220 even with prolonged boosting, so long as ambient is less than 100 or so. It gets hotter (up to maybe 230) in prolonged stop/start traffic (no fender cooler). In winter, the return line behind the front wheel well from the cooler is barely warm, even if you try really quite hard...
As you don't want to modify the tub, think you'll have to go bigger and/or hang the cooler lower.
'77 S with '78 930 power and a few other things.
Old 07-03-2011, 08:06 PM
