scottb's Avatar
CFM rating of front A/C condenser fan?
Does anyone know the CFM rating of the front air conditioning condenser fan?
Thanks!
1984 Targa
Old 07-03-2011, 03:18 PM
wwest's Avatar
It doesn't really matter, you get the BEST cooling at the lowest blower speed, provided everything else is up to "snuff". The longer the air takes to flow through the evaporator the colder it will be as it exits into the cabin.
Oops, wrong "fan".
The answer is...NOT ENOUGH.
Old 07-03-2011, 07:11 PM
brads911sc's Avatar
This is one reason you need a supplemental condensor like a Griffiths or ZIMS to get proper cooling...
83 SC Targa -- 3.2SS, GT2-108 Dougherty Cams, 9.5:1 JE Pistons, Supertec Studs, PMO ITB's, MS2 EFI, SSI's, Recurved Dizzy, MSD, Backdated Dansk Sport Stainless 2 in 1 out, Elephant Polybronze, Turbo Tie Rods, Bilstein HD's, Hollow 21-27 TBs, Optima Redtop 34R, Griffiths-ZIMS AC, Seine Shifter, Elephant Racing Oil Cooling.
Old 07-03-2011, 07:34 PM
scottb's Avatar
I've already got a supplemental condenser. I'm looking for more air flow across the front (factory) condenser, and was wondering if anyone knew the CFM rating of the factory fan in front of the trunk compartment.
Thanks!
1984 Targa
Old 07-04-2011, 08:12 AM
ShakinJoe's Avatar
I do not think it is the fan that limits your performance but the actual condenser surface itself.
'87 Carrera - 2400 lbs of Track Beast!!
'88 Carrera Cab - Too nice for the track.
'85 Targa - Salvage title that was not caught!
Old 07-04-2011, 08:35 AM
wwest's Avatar
I would first add two ~8" radiator cooling fans to force more air, CONSTANT airflow, over the engine lid condensor. Probably could eliminate the horribly inefficient one in the front.
Old 07-04-2011, 09:02 AM
scottb's Avatar
Got it. Thanks.
Still want to know the CFM rating of the front condenser fan. Anyone?
1984 Targa
Old 07-04-2011, 01:35 PM
