5:04's Avatar
Trying to figure out how to fix a leak. Pics inside and help appreciated
Hi guys, I have a pretty bad leak that's developed. I'd like to figure out the correct way to fix it. I'm wondering how involved it is to fix it though since it's on the back of the timing covers. Will the engine need to be dropped to fix/replace whatever is in there?
that911.tumblr.com
Old 07-03-2011, 03:25 PM
db_cooper's Avatar
There is a triangular gasket and an "O" ring..not in the page you have on the page shown.
They will leak as shown in the picture.
Go to this link:
http://www.porsche.com/all/media/pdf/originalparts/usa/911_USA_84_86_KATALOG.pdf
You need 930-105-197-03 gasket and a 999-706-468-40 "O" ring. Best plan on doing both sides too. Good time to set the cam timing and timing chest. You need some additional gaskets.
Old 07-03-2011, 04:02 PM
Kirk911SC's Avatar
I just finished this repair last week on my 930. Both gaskets were leaking and oil was dripping on the exhaust.
It was done with the engine still in the car.....just jack it up and lower the back of the engine.
It's a fairly involved repair as the timing chains, tensioners, etc. have to be removed to replace the gaskets. Cams need to be retimed as well.
I replaced some other seals while I was in there as well. So far not a drop has leaked and no more smoking engine!
- '00 Dodge Viper GTS - Steel Grey - Yep...a domestic.
- '87 930 - Guards Red - Sold
- '82 911SC - Grand Prix White - Gone
- '78 928 - Silver - Long gone
- '04 Subaru WRX wagon - Sold
Old 07-03-2011, 04:24 PM
Kirk911SC's Avatar
Here's a couple of pics:
Old 07-03-2011, 04:41 PM
i believe it's the tensioner pin that's being discussed. the best way, and not the easiest repair is to replace the chain housing. the pin gets loose and wallows out the hole it was pressed into. the tensioner secures to this pin and it wobbles around too. lots of used housings around. there are other ways , like machining a custom pin and boring the housing, but that takes more time and it has to come off anyway.
206 637 4071
Old 07-03-2011, 04:56 PM
Almost Banned Once
sc_rufctr's Avatar
John
Is this the back of the pin circled in red?
- Peter
Old 07-03-2011, 05:57 PM
the back of the pin, yes. too late for epoxy.
206 637 4071
Old 07-03-2011, 09:12 PM
Almost Banned Once
sc_rufctr's Avatar
But because you can see the front and back of the pin... Is it possible to press it out and press it back in with epoxy without dissembling it further?
If it was mine I'd give it a go.
- Peter
Old 07-03-2011, 11:05 PM
5:04's Avatar
Thanks for the info guys. It looks like I'll have a project coming up in the next few weeks.
Kirk thanks for the great pics! I'm sure it'll help when i'm ready.
that911.tumblr.com
Old 07-03-2011, 11:35 PM
