e p slick's Avatar
Bilstein strut clunking kunumdrum?
Bilstein strut clunking kunumdrum. I have a clunking noise coming from both left and right front of 86 911. Have looked at entire suspension and not yet determined cause. Car has 2 year old suspension upgrades including Smart sway bars, Sanders torsion bars, RSR revalved struts, Elephant poly-bronze bushings, mono balls etc. I have lubed bushings (they have zerk fittings) etc but cannot find clunk source. Thought shock came loose from inside of strut housing so dropped the top from mount (see photo) but found that strut appears to be permanently sealed with steel cap. My question is: Is top cap removable? Is assembly able to be reassembled without compression press? I don't want to destroy any parts so figured I'd best ask this learned board.Any suggestions appreciated.
EP Slick - Arizona Territory
AMG V8 SL55 Mercedes, 993 C2, 86' Carrera 3.6 hot rod, Purple 1998 993 that didn't make the cut, 3 very old 930s, A/Fuel Dragster CH3NO2 (R.I.P.), Blown Alcohol TAD, AA/AA, 360 Maxim wingless, Cummins Turbo Diesel. Amateur Welder, Painter and sculptor sort of. -
Old 07-04-2011, 10:24 AM
Navin Johnson
TimT's Avatar
There is a bushing in the top of the strut that sometimes wears, and will clunk... however I don't think two year old struts would wear like this,
Also you don't need a strut compressor to dis-assemble the strut. There is a roll pin on the bottom of the strut just above the wedge bolt ..drive that out, then pull the insert
'69 911 GT-5
'75 914 GT-3
and others
Old 07-04-2011, 11:13 AM
ShakinJoe's Avatar
EP,
Clunking is kind of vague! Is there play between the insert and green body? Is it a wheel bearing?
If all seems solid look at the front torsion mounts where the spherical washers are used. If this are over torqued which is easy to do, then this will cause a nice clunk and should not be driven! Ask me how I know?!
Could also be in steering rack. Vibrations???
'87 Carrera - 2400 lbs of Track Beast!!
'88 Carrera Cab - Too nice for the track.
'85 Targa - Salvage title that was not caught!
Old 07-04-2011, 12:14 PM
Mr9146's Avatar
The roll pins that hold the insert can break, too. Rare, but it happens.
Check ball joints, tie rods and camber mounts, too.
Old 07-04-2011, 12:26 PM
KNS KNS is offline
I had a Bilstein strut that was clunking - turned out it was bent
Edit: My clunking happened over bumps, driveways, etc.
Kurt
Old 07-04-2011, 01:02 PM
e p slick's Avatar
No play between insert and green housing. Clunking sound happens when entering/exiting potholes, bumps, severely irregular surfaces. Sounds like something is unloading by maybe 1" and bottoming out with enough force to make the noise. No vibrations at any speed. Steering rack solid and secure. Wheel bearings good with hub properly secured. Don't know about spherical bearings on front torsion bar mounts but will investigate. Thanks
Originally Posted by ShakinJoe View Post
EP,
If all seams solid look at the front torsion mounts where the spherical washers see used. If this are over torqued which is easy to do, then this will case a nice clunk and should not be driven! Ask me how I know?!
Old 07-04-2011, 01:09 PM
ShakinJoe's Avatar
I would check the spherical washers at this point. You can do it visually and quickly. PM me if you need assistance.
Old 07-04-2011, 02:21 PM
175K911's Avatar
I've had upper strut mount bearings wear out after a couple of years of track use, the bearings hammer into their races then start to make noise. Weren't ER monoballs though.
Might also want to check the spherical ends of the sway bar drop links to see if you have any slop in them.
Ed
'86 911 Coupe (endless 3.6 transplant finally done!)
'14 Jeep Grand Cherokee 3.0 Turbodiesel (yes they make one)
'97 BMW 528i (the sensible car, bought new)
'12 Vintage/Millenium 23' v-nose enclosed trailer
Old 07-04-2011, 02:25 PM
ShakinJoe's Avatar
Ed,
Good call. Maybe even a loose drop link.
Old 07-04-2011, 02:42 PM
175K911's Avatar
Yea, I think driving all these performance oriented parts on the street is harder on the pieces than track duty.
Ed
Old 07-04-2011, 03:05 PM
I had the same clunking sound from the passenger side strut, removed the roll pin and it was grooved. Installed a new one and the clunking sound is gone.
Roger B.
Old 07-04-2011, 04:35 PM
e p slick's Avatar
Front torsion bar mount spherical...
Front torsion bar mount spherical assembly is poly-bronze with zerk fittings and move freely.
EPS
Old 07-04-2011, 05:43 PM
