Scott S's Avatar
Suprised - no bushings on throttle linkage?
Hi All –
I was test fitting the throttle linkage for my carb conversion last night and initially thought I was missing some bushings. No big deal, grabbed the PET to get the part numbers. I was surprised to find there are no bushings shown for the ball/socket joint where the cross bar attaches to the brackets that are bolted to the intake manifolds (see pic below - the joint between #12 and #15). Is this really the case?There is definitely some slight friction on this joint. Other than simply greasing this, is there anything additional you would recommend doing? I made sure there were no burrs on anything – the joint just seems a little “cheap”.
Thanks!
Scott S
- A pile of British stuff
- A growing pile of German stuff
... oh, and two Hondas - complete with car seats and pounds of fish crackers smashed into the carpet (and seats, and door pockets, etc etc etc....)
Old 07-08-2011, 08:56 AM
Member 911 Anonymous
DRACO A5OG's Avatar
I just replaced Part #23's on my 3.2, right behind the driver side intake manifold Cylinder #3.
Use a dremel and polish them out good before greasing. I found washing the engine promotes corrosion due to excess moisture that sits there and all pivot points (bell housing, clutch helper arm shaft), my observations.
Jim
'85 Carrera Targa
PCA/POC
Old 07-08-2011, 09:05 AM
al lkosmal's Avatar
the ball/socket joint just gets greased. If there is too much resistance to rotation, try loosening one of the brackets and slightly repositioning it to see if this improves the condition. It may be a bit cheezy, but it's really the same type of ball/socket joint that is commonly used on linkage joints, like part #'s 21, 27, 28 shown above.
regards,
Al
PS: +1 on the mating parts being clean and smooth (polished) prior to greasing and assembling
RGruppe #669
http://www.x-faktory.com/
Old 07-08-2011, 09:12 AM
DRACO A5OG's Avatar
21,27, 28 are the type of parts I used a small polishing wheel to clean them out. they were full of debris/sand/rust The balls were horribly scored smoothed those out as well and packed with grease
The entire linkage is smooth like hot knife thru butta
'85 Carrera Targa
PCA/POC
Old 07-08-2011, 09:25 AM
Scott S's Avatar
Thanks very much all. I will make sure things are as smooth as possible, then grease them up.
Thanks Again -
Scott S
Old 07-08-2011, 09:35 AM
mcaterino's Avatar
I also seem to remember that the 'height' of one of the #12 balls was adjustable, with a double nut. This allows some adjustment of width of the gap between ends and thus tension against the coupler.
Mike
Michael Caterino
Clemson, SC
1970 tangerine (=Tiger Orange) 'T' targa
restoration: mk911.blogspot.com
Old 07-08-2011, 12:15 PM
DRACO A5OG's Avatar
Is the CIS also 1-1.5MM play at the linkage?
'85 Carrera Targa
PCA/POC
Old 07-08-2011, 04:03 PM
