new car what oil should i use
I just bought a 1978 911sc targa turbo, it has 140,000 miles on it with a rebuild done about 20k miles ago.
what oil should i be using for the summer months, I live in westchester NY it never gets up above 100F on the worst of days, usual around 85-95F Also, what type of trans fluid should i use, where do i drain the trans from, where do i fill it from Thanks Dave |
It might be a good idea to ask the mechanic you plan to use to service it.
Sergio The GT Lid Whisperer PCA 42yrs - National DE Instructor / Ex-RGruppe #197 '19 718 Cayman S (9th Porsche/1st with PDK) '14 Subaru Forester XT (Porsche support vehicle) |
i do most the service my self but I will ask one of the mechanics i know, i was wondering what other people ran in there cars.
Northern Motorhead
Dave,
Best advice i could give you is to buy a Bentley manual for your particular car and read it over a few times before you attempt any servicing ... You have to be careful because parts are expensive. There is a lot to learn about a Porsche car,eventually you will enjoy working on it yourself. As far as oil goes,i would go with a good 20W50 oil,do a search,there are endless posts on the subject !!! Cheers! Phil
Cheers Phil 89 Coupe,Black,95 3.6 engine and the list goes on ... 1983 944 SP2 race car PCA #96 |
there are about 100 threads on what type of oil and trans fluid to use, which you can find using the search function.
1982 911SC, Mocal oil cooler, Bilsteins, Carrera tensioners, backdated heat, factory short shift, Seine gate shift, turbo tie rods, pop off. 2005 Mercedes-Benz C230 kompressor sport 6-speed (daily driver) |
What's presently being used?
Doyle
Recording Engineer, Administrator and Entrepeneur Designer of Fine Studios, Tube Amplifier Guru 1989 Porsche 911 Carrera Coupe 25th Anniversary Special Edition Middle Georgia |
Member 911 Anonymous
Engine
10.5 quarts: Valvoline VR1 20W50 (non-synthetic) Mahle OC54 Oil Filter Drain Sump and Crank Trans: 3.5 quarts: Kendall 80W90 ( if you have LSD, 80W90 with LSD Additive) 1 fill/check level 17MM Allen Bolt on the side and 1 Drain 17MM Bolt at the bottom. Just make certain the fill bolt can be removed before draining the trans, it need to be removed FIRST! +1 on Bentley, 101 Book or at least Haynes for Torque Settings
'85 Carrera Targa Factory Marble Grey/Black * Turbo Tail * 930 Steering Wheel* Sport Seats * 17" Fuchs (r) * 3.4 * 964 Cams * 915 * LSD * Factory SS * Turbo Tie Rods * Bilsteins * Euro Pre-Muff * SW Chip on 4K DME * NGK * Sienes GSK * Targa Body Brace PCA/POC Last edited by DRACO A5OG; 04-27-2011 at 04:23 PM.. |
Senior Advisor
Besides the Valvoline, Swepco and Brad Penn are the other choices. Check with LN Engineering for others. Do not stray from these choices.
08 Cayenne Turbo |
Castrol 20W-50
Haven't l been on this merry go round before....
Engine - Mobil 1 20w50
915 - Kendall (w/LSD additive or not) Get a small NAPA oil pump for the tranny, makes it a LOT easier to fill. Also always remove the fill plug before draining, it's a ***** if you drain it and find you can't get the fill open...
Gary R. Last edited by GaryR; 04-27-2011 at 07:05 PM.. |
Mobil 1 V-Twin 20W50, 1600PPM .... that's what I use.
Gary R. |
Senior Advisor
Notice Mobil-1 is not on the list (except there motor cycle oil) Why?
08 Cayenne Turbo |
just me
motorbikes don't run cats, and maybe they run solid lifters so they need the same oil additives that our early cars do?
1975 911s, 3.2l and 915 transmission front oil cooler RUF replica bumper ducktail and SC rear flares SW chip ssi's m&k 2 in 1 out sc front calipers PF 97 pads fuchs 16 x 7 and 8 225/ 245 toyo ra-1s 22/29 torsion bars 25mm Charlie Bars Neatrix bushings lowered and corner balanced DAS bolt in roll bar kirkey seat 5 point harnesses. http://www.hairydoggrrrage.com/ |
Gary R. |
Read the Ultimate Oil thread linked above. The problem with Mobil 1 and may other current oil formulations are recent formula changes that do not provide enough phosphorous and zinc for older engine designs.
I believe their 20W50 "regular" does (1200PPM?), know their Racing oil does, and their V-Twin 20W50 is very high at 1600PPM (advertised).. Brad Penn is fine for a road car, I noticed increased temps (20-25%) on track using it, NG for my particular car. May try it in my hot rod but doubt it.
Gary R. Last edited by GaryR; 04-28-2011 at 07:10 AM.. |
+1. I think back inhte day (when Synthetic oil was first introduced), this was an issue for some cars. Since those days, time has marched on and the synthetic formulations have changed to elminate this as an issue. At this point in time, I feel that the dino vs syth issues are mostly academic. In regular service (99% of the cars out there), it does not matter which oil you use as long as you have the proper additve package for antiwear, etc. Due tot he higher temperature tolerance of synthetic oils, those highly stressed engines (race cars, for example) may see a slight benefit from synthetic (group IV and V) oils due tot he better tolerance of excessive heat. No, I am not a lubrication expert but I have stayed at a Holiday Inn express!
