Looking good there, Tex. Looks to me that hand forming the metal for the left over is very doable.
Dude!.....I have to give you the thumbs up for diving in. Just pace yourself, and don't burn out. Remember to spend some time with the woman....They kinda get funny when the car is more fun to play with!
Thanks guys,
Kenik that sheet metal IS doable but I would rather not futz with it. It has way too much curvature for me to take on at this juncture. I can feel the clock ticking. I certainely could fab something up that is structural with out the fillets and radii but I want to avoid the Mad Max aesthetic if I can. Kelly, I HAVE been pacing myself ;) Under normal circumstances my M.O. would be to just work all day all night until the job is done but my day job gets in the way. I also have a fantastic woman who is very supportive of my projects so when we need to spend quality time she gets priority. Besides, I have to build up some points because I know as we approach my spring deadline for a working car, there are going to be some late nights =) |
Restoration design seems to have what you need, though it's a bit pricey, maybe looking for a donor is a better idea, especially if you have to mod the part, which I don't know.
Gas tank lateral support, right 1965-89: Restoration Design Gas tank lateral support, left 1965-73: Restoration Design |
Subscribed!
Good Luck Bryan - this project will be very interesting for all of us with the early cars. Cheers JB |
JB- Soon I hope to start actually adding the personal touches and getting the cars personality to come out and then this will all be a little more entertaining. For now we are in rehabilitation mode =) |
Bryan,
Looks great! I can't tell you how happy I am to see someone bring life back into that car. Todd |
is all the rust from the Seattle area? or did this car come from back East?
I like the rgruppe sticker placement BTW |
Having fun so far! Thanks for the comments. |
http://forums.pelicanparts.com/uploa...1313792188.jpg
OR http://forums.pelicanparts.com/uploa...1313792319.jpg Any use for these? Jeff |
Drivers side better than passanger. I will call you and see if we can meet this weekend.
jcl |
Day 62 || Welding in the passenger side
7Sep11 Wow! A month has gone by! I have been finding time here and there to work on the car but I finally feel like I am getting some traction! I started out trying to Tig but I am not good enough with it and made a mess trying to get the main pan in. Too much heat build up and lots of blow through or adding too much and then having to grind it out to start over. I finally switched to Mig and sticking the metal together is much more relaxing ;) Here is some of the progress so far. Pan roughly welded in and test fitting supports https://lh3.googleusercontent.com/-z...0/P1080421.JPG Battery box removal for weight reduction and really to make space for future TBD fender mount cooling...assuming I end up running some fantastic motor that is yet to be defined. https://lh3.googleusercontent.com/-1...0/P1080423.JPG Donor part for the passenger side sheet metal brought back from the Walker Swap meet! Thanks Chris https://lh6.googleusercontent.com/-E...0/P1080424.JPG patch piece cut from donor and being fit in place https://lh5.googleusercontent.com/-b...0/P1080431.JPG Re-purposing battery box sheet metal. I will be using the outside battery wall to fill in the hole where the battery boxes used to be. This will be convenient b/c they have a gusset built in for torsional strength and I can reuse the fender mounts. https://lh5.googleusercontent.com/-h...0/P1080432.JPG Finally welding in patch pieces! Mig is so much easier to tack everything together! The welds that look cold set in the image were where I was filling holes using a 'spoon' as a backer and welding from the inside. These will be ground flush. https://lh6.googleusercontent.com/-U...0/P1080434.JPG Pan with added welds and then etch primer applied. I taped off the areas where welds will be placed and this area will be painted with POL copper rich weld through primer. https://lh3.googleusercontent.com/--...0/P1080444.JPG https://lh3.googleusercontent.com/-x...0/P1080445.JPG Seam seal applied. https://lh3.googleusercontent.com/-u...0/P1080447.JPG |
New passenger side longitudinal ground clean. The factory coating is not very durable so this part was stripped and I will etch prime and use copper rich primer at weld joints. Eventually this part will be protected on the outside with epoxy primer and the interiour will get 'cavity wax'. Waxoyl seems to be what is available and has been used for years by the Rover and Triumph/Brit car enthusiasts.
https://lh6.googleusercontent.com/-W...0/P1080446.JPG Longitudinal support finally welded in! https://lh4.googleusercontent.com/-h...0/P1080448.JPG Longitudinal 'stitch welded around the perimeter of the part for added rigidity (and as added insurance beyond the plug welds around the perimeter...remember I am not a professional welder and paranoid about my own ability at this point ;). Now I am ready to dress the welds a bit and then move on and weld in the A Arm support plate (sitting on the pan to the left) https://lh4.googleusercontent.com/-K...0/P1080451.JPG |
Wow, that looks like a great job, Bryan!
Nice work! You're going to be done in no time!
| All times are GMT -8. The time now is 11:35 AM. |
