Carl83911's Avatar
Intermittent delay when starting..
Hello folks,
I've began to notice intermittently that when starting, the starter doesn't crank right away. There is a 1 to2 second delay before cranking.
Today, when I fist turned the ignition, nothing happened. I can hear a buzzing sound but no crank. The starter cranked the second try.
My battery is only 1 year old and is fully charged and my starter is a High Torque starter installed approx 2 years ago.
Could the solenoid be acting up? Or maybe I need to replace or clean my ground straps.
Any input would be greatly appreciated.
Carl
Carl,
Old 07-14-2011, 12:16 PM
Member 911 Anonymous
DRACO A5OG's Avatar
Yeap, sounds like the solenoid, check the connections.
'85 Carrera Targa
PCA/POC
Old 07-14-2011, 12:29 PM
dshepp806's Avatar
Connections or solenoid (+1)
Doyle
Recording Engineer, Administrator and Entrepeneur
Designer of Fine Studios, Tube Amplifier Guru
1989 Porsche 911 Carrera Coupe
25th Anniversary Special Edition
Middle Georgia
Old 07-14-2011, 02:21 PM
RETIRED
Joe Bob's Avatar
Or low battery.....due to loose connections....
2012 ML350 3.0 Turbo Diesel
Old 07-14-2011, 03:01 PM
