Intermittent delay when starting..
Hello folks,
I've began to notice intermittently that when starting, the starter doesn't crank right away. There is a 1 to2 second delay before cranking. Today, when I fist turned the ignition, nothing happened. I can hear a buzzing sound but no crank. The starter cranked the second try. My battery is only 1 year old and is fully charged and my starter is a High Torque starter installed approx 2 years ago. Could the solenoid be acting up? Or maybe I need to replace or clean my ground straps. Any input would be greatly appreciated. Carl
Carl, |
Member 911 Anonymous
Yeap, sounds like the solenoid, check the connections.
'85 Carrera Targa Factory Marble Grey/Black * Turbo Tail * 930 Steering Wheel* Sport Seats * 17" Fuchs (r) * 3.4 * 964 Cams * 915 * LSD * Factory SS * Turbo Tie Rods * Bilsteins * Euro Pre-Muff * SW Chip on 4K DME * NGK * Sienes GSK * Targa Body Brace PCA/POC |
Connections or solenoid (+1)
Doyle
Recording Engineer, Administrator and Entrepeneur Designer of Fine Studios, Tube Amplifier Guru 1989 Porsche 911 Carrera Coupe 25th Anniversary Special Edition Middle Georgia |
RETIRED
Or low battery.....due to loose connections....
1983/3.6, backdate to long hood 2012 ML350 3.0 Turbo Diesel |
