Help removing Recaros
Despite pushing the seats as far forward as possible, I can get enough access to the bolts at the rear binding the sliders to the stock rails. Any suggestions?
What year/model car?
1981 911SC ROW SOLD - JULY 2015 Pacific Blue Wayne |
78 911
If stock mounting bolts, you'll need a short 10mm socket. A racheting closed end wrench may work as well.
If possible, post a pic or two so we can see exactly what you do.
Slide it all the way back-remove the fronts- then slide it ahead to get the rears.
My seats won't slide all the way forward till the front bolts are removed.
Pete 79 911SC RoW "Tornadoes come out of frikkin nowhere. One minute everything is all sunshine and puppies the next thing you know you've got flying cows".- Stomachmonkey |
Wish I had a better photo, but I'm working from my iPhone tonight
yfrog Photo : http://yfrog.com/khxsjgj Shared by nikicicicic |
I too struggled with this, I finally ended up using a special allen wrench that had one end machined ( rounded ) so you can come in from a angle. It took forever and I used up all the cuss words I knew but I finally got them bolted in.
Steve 73 911T MFI Coupe, Aubergine |
Tim
Swapped my WRX Sti MY02 for a Porsche 911SC '83 Keep buying parts to make it look older. Mid life crisis is now in its 12th year. |
I misunderstood the OP. I thought he had already done that.
Sorry for the confusion guys - I tried the front first but after seeing how small the space was, I figured the trick was starting with the back. Focusing on the front: I think the trick sounds like it finding a tool that can grip the head of the bolt in the very limited space between the rails.
Recommend that once you get them out, replace them with allen key head bolts - makes it so much easier next time.
Bandwidth AbUser
Yes, Allen head bolts are the way to go.
Jim R. |
Smart suggestion!
