privatepang's Avatar
3 fuse panel in engine bay
Hey can anyone tell what fuses are meant to be int he 3 fuse panel within the engine bay?
Its a 75 911s and I've tried searching for it but most ones i've found are for SC's.
I had to replace mine and I think it should 25 16 8 from top to bottom (just need to confirm as the part that came from Pelican had 25 25 16)
1975 Aubergine 911S - Barney
"When that doesn't work, and it doesn't quite often, it's as though your face has been amputated." - Jeremy Clarkson
Old 07-13-2011, 12:10 PM
The 2 bottom are fuses for the blower motor on the engine and the relay is also.
The top fuse is for SSportomatic.
Bruce
Old 07-13-2011, 12:57 PM
Ok. I have a 5speed manual so i assume the top one isn't required and theres onky 1 wire connected to it.
Do you know what the fuse types should be on the bottom 2?
Old 07-13-2011, 01:03 PM
bump
Old 07-13-2011, 03:54 PM
83 911 Production Cab #10
JJ 911SC's Avatar
Do you have defrost line in the back window?
Who Will Live... Will See
Old 07-13-2011, 04:46 PM
Good question.
I'm not sure as my heater blower is currently disconnected. I'm in need of a new one as I believe this one is broken.
Old 07-13-2011, 04:58 PM
JJ 911SC's Avatar
Do Not Rely On This until some one who own a 75S confirm.
I did a google search and a company that sell the 3 fuse board for a 75 shows 3 Blue one (25 Amp)
On mine, 1983 with no defrost (CAB):
Top one got only one wire with no fuse;
Middle is a white one (8 Amp); and
Bottom one is blue (25 Amp).
Old 07-13-2011, 05:02 PM
Ok thanks for the reply. Anyone with a 75 911s can chime in?
I think i got the base model. No power windows sunroof etc.
Old 07-13-2011, 05:05 PM
JJ 911SC's Avatar
This may interest you; Amazon.com: 1974-1975 Porsche 911 11" x 17" Color Wiring Diagrams: Automotive
Old 07-13-2011, 05:08 PM
Did your car come with the fuse cover? The information is molded on the inside.
If not, here is the inside markings from a 75 cover
Old 07-15-2011, 04:43 PM
