co mixture effect timing??
Previous post indicated that after changing the CO mixture to also check the ignition timing. Is this true? I don't see how the mixture could change the timing. Anybody know? 81'SC
Old 03-07-2002, 12:29 PM
Changing the mixture can't affect the timing (the base timing on an SC is mechanically fixed by the distributor),
but I'd think that changing the timing can affect the mixture.
Old 03-07-2002, 12:42 PM
I'm getting ready to smog my car and I adjusted my timing from 10 degrees advanced back to TDC. Would this richen or lean the mixture?
John
1997 993
2012 991
Old 04-20-2002, 11:46 PM
John, your car should be 5 degrees BTDC with vacuum hoses disconnected. If you set it to TDC, your car will run terrible and may cause engine damage. 81'SC
Old 04-21-2002, 12:03 PM
........what kind of engine damage? I'm not driving the car right now because I'm in Michigan. It doesn't seem to run terrible and I'm getting better gas mileage. I've been driving around with it at TDC for only 3 days. Hopefully it hasn't caused anything severe.
John
1997 993
2012 991
Old 04-23-2002, 04:03 PM
>> bump <<
........anyone?
John
1997 993
2012 991
Old 04-24-2002, 10:21 AM
John, all I know is when my timing was set to TDC by mistake, It ran terrible. Didn't think I would make it home. 81'SC
Old 04-25-2002, 03:57 PM
I believe when you retard the timing, you will get less HP, but better low-end torque (to a degree).
I believe You will get a better combustion burn at the lower RPMs (better mileage), only if your CO is set for this newer timing. Your higher RPM power (HP) will suffer.
There are many things that will affect your CO settings in the low, mid, and high end.
Good luck.
Nick
'85 Carrera
Old 04-25-2002, 05:48 PM
Cool
I'm w/Nick on this one...to my understanding, the best way to plot an advance curve is on a dyno...a comprise due to variables is a good shot...that comprise takes your driving style and engine use into consideration and of course engine set up...Ron
Ronin LB
'77 911s 2.7
PMO E 8.5
SSI Monty
MSD JPI
w x6
Old 04-25-2002, 06:04 PM
