TIA SmileWavy |
The photo below shows the pipe cap and hand screw I used. The size on the pipe cap says 1 1/4" which I believe is the I.D. of the pipe. The size of the opening or the O.D. of the pipe looks to be 1 5/8". I took the dust cap to the store to get the right size. This size works for my car an 86 Carrera. I like the wood hand screw because it won't mar the metal, but I'm sure you could use a c clamp. Hope this helps. http://forums.pelicanparts.com/uploa...1311210822.jpg
Perfect!
I am re-installing the caps now, all rears have popped off again. :( Thanks Brother! |
OK, I see now, I'll try the pipe cap method next time, Thanks.
This method work with me... 2 clamps to keep seal in place, and tap the clip in between the 2 clamps with a piece of wood.... snaps right in.
http://i169.photobucket.com/albums/u...7/DSC_1190.jpg |
OK trying this method right now:
http://img.photobucket.com/albums/v5...720_191354.jpg Will post an update :D, It was yummy :) |
Update:
Gerber Cap is too weak, it gets warped. Made a SST out of Black PVC 1.5" Connector, Cut out spaces for my Wood Vise. It seemed to slip on but as soon as I loosen the vise one side pops out. Tried again, with a bit more pressure. BROKE thru the rubber at the connection of the Barbed Wires. WHAT A POS!!! |
I do most of my own maintenance and upgrades but when it comes to brake calipers I use Eric at PMB Performance. Awesome restoration complete with original plating.
http://forums.pelicanparts.com/uploa...1311224509.jpg |
Here is the tool I made, took a break and tried again, it actually worked but will need to do it two inner one again. Thanks FAG :eek: ( that's what is says on the boot )
It would have been easier and more accurate if it was off the car, :eek:. Live and Learn. 1.50" PVC, used a dremel to cut out the section for the wood clamps: http://img.photobucket.com/albums/v5...720_215724.jpg |
Only a dust boot clip. This is totally crazy. Why don't they make it so that they can be as easy as the front?
I was thinking there must be more than just me with this issue and I bet most or even shops that installed these boots probably popped off??? In any case, If I need to service just the boots, I am thinking I can place a slight groove with a dremel around the rim to make the CRAPPY FAG Boot to bit into??? I mean that is all that needs to be in place is a lip to catch those silly barbs, right? or is there better boots or pistons for the rears out there??? |
| All times are GMT -8. The time now is 06:54 AM. |
