Home of the Whopper
How to pickle MFI pump?
I have an MFI pump that has been sitting for about 40 years. I would like to properly clean it out and put into long term storage. Anybody have any suggestions on how to clean it out and how to properly store it?
Thanks,
BK
“The wave is not the water. The water merely told us about the wave moving by” – Buckminster Fuller
Old 07-15-2011, 05:38 PM
HarryD's Avatar
There are threads somewhere on the topic but in reality, unless you are going to use the MFI Pump soon, why bother? After all, whatever problems you are going to have, they are already in place. You will need to address them when you need to put the unit into service.
Harry
1973.5 911T Targa - "Smokey"
2020 MB E350 4Matic
Old 07-16-2011, 04:37 PM
Home of the Whopper
I kinda thought that too, but also thought about not making it worse. I think I will clean it all out with carb cleaner, let it dry, fill with oil, then plug.
Old 07-16-2011, 06:41 PM
304065's Avatar
mmo
'66 911 #304065 Irischgruen
‘96 993 Carrera 2 Polarsilber
'81 R65
Ex-'88 Carrera (Sold 3/29/02)
Old 07-16-2011, 07:20 PM
Max Sluiter
Flieger's Avatar
He means Marvel Mystery Oil
Old 07-16-2011, 07:43 PM
i pickled a bosch fuel pump 50/50 mmo/20w non-detergent
Ronin LB
'77 911s 2.7
PMO E 8.5
SSI Monty
MSD JPI
w x6
Old 07-17-2011, 02:22 AM
Home of the Whopper
Thanks guys.
I pulled off a few of the covers to take a peek. I am no expert, but everything looks ok to me. Everything appeared to work properly.
These pics were taken before cleaning. I do not see any need to clean anything.
Any pointers on exactly what and how to inspect?
Old 07-17-2011, 01:39 PM
Home of the Whopper
Monday bump
Old 07-18-2011, 07:26 AM
356RS's Avatar
Your pictures indicate a very clean pump inside. As long as the main control rack springs back after being gently pushed in and all six plungers are moving up and down I think your in good shape. IMHO I would add a 3/4 gt. mixture of half & half 10 W oil and Marvel Mystery Oil into the pump for storage. Cap off the 6 delivery ports on top, the 2 fuel line banjo's and the side cover oil outlet and the 2 thermostat ports. Also I would lightly brush on some Marvel Mystery oil to the body of the pump to help keep the magnesium from starting any surface corrosion. Put it into a 3 gallon ZipLoc bag and it's ready for storage.
Mark Jung
Bend, OR
MFI Werks.com
Old 07-18-2011, 09:42 AM
