2003 911TT turn signal problem
My driver's side front blinker is out. Replaced the bulb - nothing.
All 3 other blinkers work fine. All other bulbs in driver's side front work fine also so it is not the whole light assembly. Any thoughts? Does a relay only support 1 blinker possibly?
Old 07-18-2011, 10:48 AM
rluciano's Avatar
I had the same problem on my 2003 Ruf. Take the bulb out of the socket again and look at the bottom of the socket. On mine the piece of metal that makes the contact to the center of the bulb base was broken off. Therefore I had an open circuit, maybe you have the same problem. I got a replacement socket from a wrecked Boxster, works perfectly.
Original owner 1986 944
1987 951 968 wing from CPR, Deutsche Nine headlights, KW Variant 3s, Lindsey Stage 2 intercooler, Big Reds
2003 Ruf 3600S S-Car-Go equal length headers, otherwise almost stock
72 911T w/ SC 3.3SS engine MoTeC Hargett ITBs
Old 07-18-2011, 11:55 AM
Thanks for the advice! I will give that a try.
Old 07-18-2011, 12:35 PM
