Solex 40PI service
I just completed a Level 3 remanufacturing effort on a set of Solex 40PI carburetors and wanted to share a few things I learned:
When I test ran the carbs I used a fuel delivery system other than the OEM design. I ran fuel through a pressure regulator set at 3 1/2 psi and then through an adjustable flow control valve. The fuel lines were split with each one attached to the inlet fuel lines running to the banjo fittings. Fuel was collected from the bottom of the fuel bowls on the manifolds (floats were removed) and then sent back to tank. This is a system racers have adopted to overcome some of the issues with the twin Pierburg pumps. The holes in the banjo bolts had already been enlarged to 1.2mm which was one of the early factory recommendations for these carbs. I sent the fuel pumps to Ed Fall of Vintage Werks and was extremely satisfied with his personal attention to my particular project, highly recommended! I attach a couple of pictures; the manifolds and some of the unfinished bracketry are mine and not correctly finished but the throttle bodies are per OEM. The accelerator pump jet components are displayed in their correct orientation, the throttle shaft is shown correctly configured in relation to the throttle body showing the aluminum portions for shaft support just outside of the throttle valve followed by nylon bushings and a very short bronze bearing. ![]() ![]() ![]()
Paul Abbott Weber service specialist www.PerformanceOriented.com |
