FinallyGotOne's Avatar
Why won't my intermittent wipers work anymore?
They worked, now they don't. ? 79 SC
Old 07-18-2011, 11:07 PM
Relay
Old 07-18-2011, 11:29 PM
Member 911 Anonymous
DRACO A5OG's Avatar
Key is in the ON postion, correct? Does you regular wiper work? If not check the fuse or relay.
'85 Carrera Targa
PCA/POC
Old 07-18-2011, 11:36 PM
when the points in the wiper switch don't contact with the switch off, the wipers don't park and the intermittents don't work.
206 637 4071
Old 07-19-2011, 04:13 AM
The newest of the noobs!
grendiers's Avatar
I don't see a problem with this. My intermittents don't work nor do they park correctly. However, I like that I can park them on the passenger side, and the wife can look at them instead of me!
1989 944 Turbo
2004 Jeep Wrangler Unlimited - Built!
1985 Saurer 6dm overland Swiss military truck/camper
Old 07-19-2011, 04:35 AM
na2ub's Avatar
+1. If your wipers don't park, you need to take the switch off the steering column, and re-bend / sand to fresh metal, on the switch contacts. Once the wipers can park, the intermittent function works as well. If your wipers still park fine, maybe it is a relay or rheostat.
Doug
79 SC Targa w/ ITBs, 2004 Cayenne Turbo
Old 07-19-2011, 05:27 AM
My wipers park good, and they work fine. Just the little dial by the guauges when I turn it nothing happens.
1979 911 SC
1974 OEM 911 Exhaust and Muffler - Modified to a 2-out
Fiberglas Goodies, 17" C4 Cup Wheels
Old 07-19-2011, 06:48 AM
na2ub's Avatar
The intermittant feature only works when the wipers are parked in the off position, not while they are on low or high.
Doug
Old 07-19-2011, 06:52 AM
RETIRED
Joe Bob's Avatar
Fix the intermittent, then pop the tach out and reposition the arm to move the park position to the passenger side.
2012 ML350 3.0 Turbo Diesel
Old 07-19-2011, 07:00 AM
