Odometer
I went to the Parts Obsolete event this weekend in my 85 3.2, and on route my odometer and tripometer stopped working, the speedo is working fine....so am I correct in assuming that this is likely a problem inside the gauge? (the 85 speedo is electronic so I assume there is a motor inside the instrument to rotate the tumblers based on the speedo's input. I just want to make sure that the speedo is likely the problem before sending it for repair....Thanks
Member 911 Anonymous
Yes, the wheels may have fractured for the Odo or maybe one of the green power lead solders may have fractured.
If your needle is working then it is probably the sprockets. Jim
'85 Carrera Targa Factory Marble Grey/Black * Turbo Tail * 930 Steering Wheel* Sport Seats * 17" Fuchs (r) * 3.4 * 964 Cams * 915 * LSD * Factory SS * Turbo Tie Rods * Bilsteins * Euro Pre-Muff * SW Chip on 4K DME * NGK * Sienes GSK * Targa Body Brace PCA/POC |
Thank you sir, I guess I should send it to North Hollywood Speedometer then.....
If you have to or you can ty to rebuild it yourself. Are you in Canada? If so isn't there someone close by?
NHS is great but the shipping cost???
Registered knucklehead
This might help ij your descision making process
Odometer Gear replacement for Electronic Speedometers (long) Gregg
1983 911 SC Cabriolet, 1989 944 S2 1969 Chevelle SS396 w/427 Vette motor, 1970 Buick GS455 2000 BMW 528i Touring, 2005 GMC Sierra |
If you want to DIY, do a search and you can find procedures and a source for the gears. If you send to NH Speedo, it's about $140. I had them do one of mine a couple of months ago. Ken
Ken in Greer, SC 88 Carrera Coupe 98 C2S Coupe |
Haven't investigated the availability of local talent for this job, so I'll do so. Thanks for the self repair thread, very useful.....I may even elect to "give it a bash" next winter. Cheers
