<insert witty title here>
compression/leakdown results, 3.0L
150k on the engine
135/10 140/8 140/7 135/8 135/7 135/5 Thoughts?
Current: 1987 911 cabrio Past: 1972 911t 3.0, 1986 911, 1983 944, 1999 Boxster |
Track car? Weekend driver?
"A machine you build yourself is a vote for a different way of life. There are things you have to earn with your hands." |
3 or 4 track days a year, daily driver in the summer, 8-10k km per year. Would be a replacement for my 2.4L.
Platinum Member
Where is it leaking from? with 10% you should hear it out the exhaust, intake, or case, which would tell you if it's from valves or rings.
Don't know, just got those #s from the seller.
Would 10% on the one be anything to be overly concerned about? I'd like to get at least 4 or 5 years and 30k miles out of this engine before opening her up.
Chris - is the engine local to you? 10% is up there, but like everything in life its who is doing the testing. Maybe you could go and check it out yourself ???
Brad - 86 Carrera (Doc) |
Platinum Member
IMHO that test is incomplete and should give you more info. 7-10% is showing wear, which would be expected on a 150k mile engine. If I was buying/checking this out, I'd be more comfortable knowing it was leaking through the valves, and if so, I'd think about freshening the heads while the engine was out, or at least monitor the compression/leakdown annually looking for change.
As to a 30k mile guarantee, I don't think they were that long when new.... but I'd give it even odds of lasting 30k miles if I was a gambling man. |
Not local, no - about 4000 miles away. The 30-40k mile/4-5 year is based on when I think I'll actually be able to get around to a DIY rebuild
oh that is a hike. I did a quick google for the numbers - as I said - numbers alone are no real indicator. One quote form Wayne Dempsey -
The following is a quote from Wayne Dempsey's "How to rebuild and modify Porsche 911 engines". A book I regard highly.
Funny, I asked them when I was there last week, they said 16! I might just try to sneak her out for a few laps...
![]() I know it's a bit of a gamble, and I'm trying to weigh the risks and benefits. In the end, it's not like it's huge money, but still, I'd hate to get a year out of it then need to rebuild it.
Mike Holbrook
I would drive it a while, adjust the valves and re-test. In any case, 3.0 engines are great.
Mike Holbrook Meridian, ID 1979 911SC Targa |
The engine - check to see if a Pelican can check for you ??? I did that when I was looking at a 3.2 in Philly back in '06.
as for your daughter, I was taking Holley out in the car for 2 or 3 events ( evenings ) then I was confronted by staff (female) about not doing it ... after I discussed things with her - she had me sign the junior dragster entrant form/waiver. Hey they are on track racing. I drive different with her in the car - she is only 8 - but she watches the data and tells eveyone she likes going "G speed" which is anything over 1.? g. we should meet at cayuga one wednesday/friday evening Brad
You bet - I plan on going at least once a month for the rest of the season. It's so close, and so cheap. I wish Mosport was that close!
ya I know - for me its less than 30 minutes away -
I would not pull the engine for a rebuild just on 10% leakage. But, that is me.
Porsche 2005 GT3, 2006 997S with bore-scoring Exotic: Ferrari F360F1 TDF, Ferrari 328 GTS Disposable Car: BMW 530xiT, 2008 Mini Cooper S Two-wheel art: Ducati 907IE, Ducati 851 |
Home of the Whopper
10% does not scare me, but one at 10 and one at 5 is a little concerning. As others have stated, you need to know where the leakage is from. If a valve, you could pull a head and lap a valve. That may drop it some. If rings, nothing you can really do without a tear down.
As a reference, my 914 is about 12% across all 4 and runs great.
1968 912 coupe 1971 911E Targa rustbucket 1972 914 1.7 1987 924S |
Platinum Member
Would you buy an engine with 10%, take out a good motor, install the 10% motor, and expect it to last 30k miles? Not sure I would...... |
10% leak in one cylinder = a lower price.
You pay your money you take your chances.
I would drive for a season as is, and be prepared to fix it. A nice winter project.
Thread Tools | |
Rate This Thread | |
