jbrown's Avatar
throttle body rebuild kit
where can i get a throttle body rebuild kit for a 77 turbo motor?
Old 07-19-2011, 12:37 PM
Member 911 Anonymous
DRACO A5OG's Avatar
I wanted one for my 3.2 and buddies '86, it is a no go. only choice availble is to buy new $600 I only needs the damn bushings. His bushing is broken.
Found some at Mc Master Carr but found out it was the pivit behind the Intake manifold that failed on both of our babies. They are metal coated in teflon bushing, tend to wear over time and rust causing severe binding. I post a thread on the tutorial.
Even with the broken bushing at the throttle body, the repair made his TB smooth as butta , we just lube that sucka
Jim
Jim
'85 Carrera Targa
PCA/POC
Old 07-19-2011, 01:09 PM
Jacksonville, Fl
Reviving this thread, seeing as its been a while.
I discovered through a smoke test, that I have a significant vacuum leak at the throttle body.
I spoke to a Gentlemen at Maxbore who can rebuild these, but would need a customer provided kit to do it. Does anyone know if there is a rebuild kit out there?
Alex
Jacksonville, Fl
'88 Carrera, Guards Red
Old 06-28-2017, 11:50 AM
Jacksonville, Fl
Anyone?
Alex
Jacksonville, Fl
Old 06-29-2017, 04:49 AM
Registered Minimalist
75 911s's Avatar
Contact Tony, boy911sc is his username. he has a small army of CIS throttle bodies and parts. He probably has what you need either in a parts tb, or individual parts.
Duane / IG: @duanewik / Youtube Channel: Wik's Garage
Check out my 75 and 77 911S build threads
Old 06-29-2017, 06:52 AM
