Nope! Not a rally car... :-)
I'll give you guys a hint, this is how it sounds from outside: http://195.22.79.154/temp/stafras.mp3
Thank you for your time, |
Richard,
your car sounds ace! Now I have to figure out if I should go for that type of exhaust in foreseable future or wait for the very distant future (cost) and buy SSI to get extra power aswell as good noise.
Chris - - - - - - - - - - - - - - - - - - - - - 1982 911 SC Hellblau Metalic - - - - - - - - - - - - - - - - - - - - - 1997 Boxster 986 2.5l |
ok, its a porsche right??
(clutching at straws )
Rich ![]() '86 coupe "there you are" |
Richard:
Of course...it's a (acustical) inside tour in 917 climbing trough gears... I should have waited for someone to reveal this but i couldn't stand see you suffering :-)
chris - thanks! i guess you have a power issue with an sc, you've got more to gain (than with a 3.2) going with ssi's.
do your std. heat exch cross over like the 3.2? and then you've got a premuffler and 1 in/1 out muffler? is that right? what have you got?? decisions decisions!! beepbeep - what d'i tell ya? i knew it! actually i didn't av er frickin clue
Guest
Posts: n/a
I didn't have a clue either
If there're more 917 sounds were that came from let us have the links please.
Richard,
My system (standard) looks just like the original one on your car with the exception of the cat. It just has a pre silencer.
i see your predicament!!
i suppose it depends how much you want the extra power and how long you gonna have to wait. if its a real long time then it doesn't matter what you do now cause you'll get use out of what ever you've got! hope that helps
