Hendog's Avatar
Will 225/45/17 fit in front?
I'm currently running 215/50/17 on the front with rolled fenders. I'm in the process of upgrading my suspension and will be re-shooeing the car as well. I'm wondering if anyone is running the wider size up front?
Henri
Owned for 21 years: '87 Carrera coupe Venetian blue
Old 07-21-2011, 09:34 AM
KTL KTL is offline
Schleprock
KTL's Avatar
225/45-17 is the typical choice for people looking to go wider in the front. You're on the right track with rolled fender lips. Rolled lips and more/max negative camber is key for clearance.
Some people actually run 235/40-17 in front on a car with std. front flares. Key is to make sure your wheels are an offset that pushes the wheel as close to the inboard side as possible. +30mm is a good target for a 8 in. wheel. Many people who run 225, 235, 245 width tires in front will also remove the metal shock absorber cover, or replace with a rubber accordion boot type, to clear the strut.
Kevin L
'86 Carrera "Larry"
Old 07-21-2011, 11:34 AM
FinallyGotOne's Avatar
On my 79 911 with rolled fender wells I run these:
Front 225-45-ZR 17
R 255-40-ZR 17
Never had any troubles.
1979 911 SC
1974 OEM 911 Exhaust and Muffler - Modified to a 2-out
Fiberglas Goodies, 17" C4 Cup Wheels
Old 07-21-2011, 11:35 AM
Bill Verburg's Avatar
An informed answer cannot be provided w/o knowing the o/s and width of the wheels used, ride height and suspension setup are secondary concerns and would be necesary to know in extreme cases
Bill Verburg
Old 07-21-2011, 11:37 AM
Hendog's Avatar
I am somewhat ignorant on offset spacing so bear with me if the following provides no information: There are no spacers on the hubs. I believe the front wheels are 7", given the rears are 8". Wheels and rolled fenders are courtesy of the PO.
I would like to replace the fronts with the size I currently have, 215/50/17 since that has worked well so far. Unfortunately the tires I am looking at don't appear to come in that size but are available in 225/45/17; Bridgestone PSS-04 as featured in an earlier post.
Henri
Old 07-21-2011, 12:35 PM
again you need to provide the ET of the wheel
as the ET goes down the wheel faces move further outboard, 7 ETxx w/ 215/yy x zz may fit fine but the extra width of a 225 could interfere.
stock 911 front fitment w/ Fuchs was 7x15 ET23.3 w/ 205/50 or 205/55 x15 tires, no issues
many users have put 7x16 ET23.3 w/ 205/55 x16 tires and found it to be tight r even too tight at the lips
on the other hand an 8 17 or 18 w/ 235 or even 245 can be fitted if the ET is right
look closely at the wheels ET is often a 2 digit # near the valve stem or on the back of the wheel somewhere
You are looking for something like ET23 or ET25
Bill Verburg
Old 07-21-2011, 01:23 PM
Hendog's Avatar
No ET
Bill,
Again, my knowledge is limited; I'm not familiar with what ET relates to, but I'm willing to learn.
There are no markings on my wheels similar to your example. I've tried to find out years ago what wheel I have but no one was able to identify it. I've run into a couple guys who've had the same wheels on their cars, but like me, they acquired them with the car. They're a knock off of the 1993 Turbo I believe. Japanese made. Good quality. I weighed a rear wheel only (no rubber) and it was 18-19 lbs. I like them, but they are showing their age.
Below are the markings on the back of each of the five spokes. No other markings to be found. Not sure if anything can be deduced from these.
Henri
Old 07-21-2011, 09:15 PM
WPOZZZ's Avatar
Henri - I believe your offset is in this picture. It looks like it is Et10. FWIW, I just bought a set of 17x8s and 17x9s of the same rims last week.
Old 07-21-2011, 10:10 PM
Jeff Alton's Avatar
Henri,
Shoot me an email or drop by with a front and rear and I can measure them for you and give you some thoughts about what will or will not fit...
New address, so don't swing by the old place
Cheers
www.turn3autosport.com
Old 07-21-2011, 10:33 PM
KTL KTL is offline
Schleprock
KTL's Avatar
Who makes the wheels? Looks like a copy of the 964 Turbo 3.6 Speedline Aliseo wheels (those where 18 in. I believe).
Kevin L
'86 Carrera "Larry"
Old 07-22-2011, 07:29 AM
