Northern Motorhead
Racing seat installation... looking for advice !
Hey guys,
Caught the DE track bug real bad and i want to install some Sparco racing seats and harnesses in my 89 Coupe. I have a Das roll bar already installed and i'm getting a real good deal on the seats,side mounts,bases and sliders.I plan on using six point harnesses. Now what i need to know is concerning the tunnel mounts ? I read something on another post that the 87 and up cars already have the threads in the tunnel for the eyebolts ? Can somebody please enlighten me on the installation process ? Thank you ![]() Cheers ! Phil
Cheers Phil 89 Coupe,Black,95 3.6 engine and the list goes on ... 1983 944 SP2 race car PCA #96 |
Recreational User
By "tunnel" are you referring to the center tunnel or the rockers? The rockers are where you install the eye bolt using the existing lower seat belt mounts.
All the SCs and Carreras and everything that came after that have the seat belt receptacles attached to the seat, not the center tunnel. There is no provision for an eye bolt on the center tunnel. What you need is this 964 RS mount that goes between the inboard side mount and the seat slider:
Recreational User
Here's more information about the part in this thread -> Recaro PP, mounting and where to buy?
Scroll down to Bill Verburg's post #15. These can be bought right here on Pelican. |
Northern Motorhead
Dave,
Yes i was refering to the inboard sides ...My supplier has a bunch of "eyebolt" receptacles in stock which i will mount on the rocker sides where my roll bar attaches,i was just wondering about how to attach the inners ? Do you have any other pictures of how the 964 RS mount is installed ? I kind of figured everything wouldn't be a direct bolt on ... Cheers ! Phil
Not my SC, it has mount tabs from the factory on the tunnel for the inboard seatbelt mounts. I thought they switched over in 84 or 85.
Mike Bradshaw 1980 911SC sunroof coupe, silver/black Putting the sick back into sycophant! |
Platinum Member
The correct way is to mount the seat where it is comfortable, then install the harnesses per the manufacturers instructions.
For example, Schroth has installation instructions (pdf files) here: Schroth Racing Harnesses |
Schleprock
964RS mount sounds like a good idea but last time I tried, Pelican couldn't obtain them.
Brey Krause makes an inboard seat adapter plate R-9005 that works nice. I used it for my Cobra Imola S seat install in my '87. Brey-Krause Harness Installation Brackets for Porsche
Kevin L '86 Carrera "Larry" |
Recreational User
Right you are! I checked PET and '85 was the model year when they made the switch to seat-mounted belt receptacles. I coulda sworn it was '78.
If the RS mount isn't available thru Pelican it certainly is available at any dealer, be sure to order the matching 3x 3mm washers to keep the seat base level. The only additional complication is if you want to retain the stock seat belts. On mine I use the RS tunnel side mounts for the stock seat belts and drilled holes for pad-eyes for the harness to clip to. I second Dad911s recommendation to read the Schroth installation instructions, to do it right is not as easy as one might at first imagine
I drilled holes in the top of my tunnel just forward of the access panel for the shift linkage. It's tight in there but easy enough. I used the standard eye bolts, nuts and big backer washer.
Chris 87 Carrera Coupe - Guards Red on black 00 Carrera Cab - White on Navy 05 Carrera S - Atlas Grey on gray 86 951 - India Red on black - Sold |
If your passenger seat is non power, the inside mount can be used. The inside mount on non power seats is not welded to the seat slider/lift structure like the power seats.
I went through the inside mount issue on my 87 and ended up using the Brey Krause inside mounts shown in KTL's link. This is rattling around in my "extra parts" box. I only have one but you're welcome to it if you want it.
Don 24 Cayman GTS - GT Silver 23 Cayman GTS - Arctic Grey - Sold 97 993 Coupe - Arctic/Black - Sold 13 991 Coupe - Platinum/Black - Sold, 87 911 Coupe - Venetian Blue |
Also, the seat manufacturers are being very specific in their allowable methods for installing their seats. For example, FIA rated seats, like a good Racetech or higher end Momo etc are to be mounted with certain approved mounts in certain ways, and they must NOT have a back brace installed. In my opinion, it's not something to be taken lightly.
Jake Gulick, Black Rock, CT. '73 yellow 911E , & 2003 BMW M3 Cab. Ex: 84 Mazda RX-7 SCCA racer. did ok with it, set some records, won some races, but it wore out, LOL[/B] |
Northern Motorhead
Wow...
This isn't as straight forward as i expected ! I was going to pick up all the Sparco parts tomorrow from my local supplier but now i'll have to wait and see because it seems i will need a bunch on BK parts as well ... From what i understand my 89 has the seat belt mounts threaded into the tunnel and the rocker side and i would need a BK bar for the 6 point anti submarine belts right ??? Thank you for the help guys ![]() I would imagine it's pretty straightforward after you do it the first time ... Cheers ! Phil
The inside seat belt mounts are on the seats. There's no threaded mount on the tunnel side. Pre 85 (I think) had the inside seat mounts on the tunnel.
Are you mounting the seat on sliders? If so, inquire about appropriate sliders and mounts from the seat supplier. As for the subs straps, typically they go through the hole in the seat, then back to the anchor points for the lap belts. Read the instructions to confirm. Your shoulder belts ...what were your plans for them? Mounting to the cage (roll bar?) cross car tube is a popular and good method. Some guys mount them to the rear deck, but I think that's sketchy in most cases, unless there is structure for, and specific to the belt anchor added. Each setup requires quite a bit of thought to do properly.
Most sanctioning bodies will want through the floor mounts directly under to 20* back from the seat hole alternately a sub bar as used on GT3s can sometimes be used Read the mounting instructions from a credible authority like Schroth pads & reinforcements for through the floor installed ![]() ![]() GT3 subbar ![]() ![]() ![]() another big mistake I often see is not having a straight fetch from the shoulder to the shoulder belt mount because the seat hole is too small or improperly located and not using a proper run on the belt attachment
From Simpson:
It's an FIA rated harness, installed in an SCCA logbooked racecar. Main see diagram B. While it's rather small, the SFI diagram shows the sub strap anchors at a location in the same plane as the lap belts. Further, G-Force, a maker of SFI and FIA approved systems, is rather open on sub strap attachment points, and advises that the sanctioning body has final say. (!) Finally, the SCCA GCR (general Competition Rules) states that the sub straps may be bolted to the floor, or may attach to the lap strap anchors. So, I appreciate your thoughts, but i think that stating that it's "absolutely and unequivocally wrong" is a bit of an overstatement.
Jake Gulick, Black Rock, CT. '73 yellow 911E , & 2003 BMW M3 Cab. Ex: 84 Mazda RX-7 SCCA racer. did ok with it, set some records, won some races, but it wore out, LOL[/B] Last edited by lateapex911; 07-23-2011 at 01:15 PM.. |
However, if you bother to look at Schroth's instructions it is clearly defined. On p15 & 16 as 0* to 20* back. An additional restriction is that the belt should not depend on the integrity of the f/g seat shell for support, in other words don't have the belt's pushing on the shell in any way. Usually you see this sort of mistake at the shoulder where there is not a clear fetch from the shoulder to the attachment point causing the belt to be deflected by the seat shell but it is equally important at the sub strap
