DG624's Avatar
No Electrical
I have a problem with starting and all the electrical parts...nothing works. It was running two days ago but now nothing... no starter or any electrical item works. The only response when starting is the fuel sending unit moves off of zero along with the oil pressure switch. Nothing else indicates the ignition switch has been turned.
The battery is fine just charged up with trickle charger, 6 months old
The battery connections are good so are the fuses.
I replaced the Motronic chip several months ago but everything ran after that.
I just replaced the O2 sensor before the problem came up.
I checked to see if anything was knocked lose but saw nothing wrong.
What could cut off all power to the engine?
Old 07-29-2011, 11:27 AM
crustychief's Avatar
Alternator connection? I would recheck the battery cables especially the ground cable at both ends of it. If you are certain the battery is good under a load test.
A nose heavy airplane flies poorly, a tail heavy plane flies once.
Old 07-29-2011, 11:34 AM
Member 911 Anonymous
DRACO A5OG's Avatar
+1, check the negative connection on battery. While you are at it double check the voltage at the posts with a DVM.
'85 Carrera Targa
PCA/POC
Old 07-29-2011, 11:36 AM
I just re read your post, there is a multi-pin connector by the 02 sensor plug that may have been jarred loose, if it is on an air cooled 911
Old 07-29-2011, 11:39 AM
Air Medal or two
afterburn 549's Avatar
the small wire on the positive side of batt post .is .....disconected? Looking at a conection does not mean they are in continuty either..confirm!
D troop 3/5 Air Cav,( Bastard CAV) and 162 Assult Helicopter Co- (Vultures) South of Saigon, U Minh Forest, Delta, and all parts in between
Old 07-29-2011, 11:57 AM
DG624's Avatar
The +battery cable is old but no corrosion and tight. There are several additional wires on the + side but they look good...I will clean them to be sure.
Can this be the ignition switch that is not allowing any power to any electrical part? The radio should work with the ignition off. The light for the front hood usually lights when I open the hood but there is no light. It seems nothing is getting from the battery to the electrical circuit. I checked the connections to the plugs on the left side of the engine but would this remove all power to the entire circuit? There is not one problem there in no current...even though the battery is fine.
Old 07-29-2011, 12:26 PM
Air Medal or two
"again" looks dont count here..verify continuty
Old 07-29-2011, 12:40 PM
86 911 Targa's Avatar
Location: Manhattan Beach, California. Factory Delivery-Original owner-Retired engineer
Originally Posted by 86 911 targa View Post
remove both battery cables from the battery and test the battery for 12v.
With the battery still disconnected, perform a continuity check
from the negative cable to ground. (there is a ground point in the boot next to the gas filler neck).
If there is no reading, you have an open negative cable to the chassis ground connection located on the driver's side luggage compartment. (bentley 270-3).
Then, with the battery cables still disconnected, place the + probe on the positive battery cable, and the negative on the top of fuse #2.
If you have continuity, then, reconnect the battery cables.
If there is no reading, you have:
An open 12v cable.
Good luck,
gerry
+1
1986 911 Targa.
Per Road and Track magazine:
Only in L.A.:
In the window of a bar in Hermosa Beach, California.
"Happy Hour prices during all car chases."
Old 07-29-2011, 02:27 PM
