Hammer gurus- odd issue, please help
Hi All,
I just got a Bosch Hammer for my '90 C4. Everything works great- I can read all the installed modules/faults, direct drive all the drivable bits (fans, actuators, etc....) but I have one issue- the Hammer can not detect when the car is running. The upshot of this is that I can't get real-time output from the engine department sensors nor do an adaptation. To be clear- I can read the DME and activate the drivable bits (like the manifold tuning valve and the IAC valve) with no issue. Further, the car runs fine, maybe even great.
I have to assume that the RPM output is making it to the DME; again, the car runs fine and is entertainingly quick.
I also have to assume that the Hammer is working correctly. It will do everything I ask of it except the stuff that requires a running engine.
Consequently, I think the issue must be with the circuitry that communicates RPM to the diagnostic jack; either there's an issue with the output of the DME *or* an issue with the relay of same (have yet to check the wiring diagram; does the jack connect to the Central Informer?)
Also, having reviewed all the Rennlist and Pelican Hammer-related posts I find that I do not have the 19-pin official Porsche plug but rather a more-generic 4 pin plug to connect the Hammer to the car. I'm not sure that's an issue, however, as all the DIY products use a 4-pin connection too and they seem to be able to read live motor data.
Any input on where to start troubleshooting is greatly appreciated!
TIA,
Robert
Old 09-08-2011, 05:21 PM
is it chipped? sometmes that screws things up.
206 637 4071
Old 09-08-2011, 05:38 PM
Dunno; not by my hand, but....
Pull out and open the DME to check, right?
Old 09-08-2011, 06:46 PM
I've done some further research and determined that my 4 prong interface cable may be the issue. John Speake of JDSPorsche fame answered an inquiry via email (immediately, I might add...) indicating that the Hammer needs to see a signal on the separate RPM signal line. He was also kind enough to tell me that the RPM pin (#14 on the car side) should be connected to Pin 1 on the Hammer end.
I'll mess about with it over the next few weeks and report back.
Old 09-09-2011, 11:22 AM
RETIRED
Joe Bob's Avatar
Another Hammer guru is Ingo, 3.6@cox.net
Old 09-09-2011, 11:27 AM
Chain fence eating turbo
Not to hijack, but will the Hammer do the same for '84-'89 DME's?
Cory - turbo'd '87 C3.2 Guards/Blk, 3.4, 7.5:1 CR, 993SS cams, Borg-Warner S366 turbo @ 1.2-1.5 bar, Treadstone full bay IC, 70mm TB, TiAL F46 WG, HKS 1 1/2" BOV, twin 044 pumps, MicroSquirt AMP'd w/GM smart coilpack, Bilstein coilovers, Tramont replica Speedlines (285's rr, 225's frt), Big Reds frt, 993 rr., tower brace, MOMO wheel
Old 09-09-2011, 12:26 PM
Dunno; good question. Do you have a diagnostic plug? What's it look like?
Old 09-09-2011, 12:39 PM
Honestly, I dunno....
Never seen one and have always been under the impression it does not.
Old 09-09-2011, 01:19 PM
Well... the Hammer has to plug in somewhere; if it can't it can't Hammer, so if you don't have a diagnostic plug then no Hammer for you! (sorry )
Old 09-09-2011, 02:12 PM
