Alternator ground wire insulation melting
![]() This can't be good. Removed alternator because I'm planning to install a new VR...
87 Carrera Coupe Black on Black, H4 Headlights, Nurburgring Sticker |
Possibly brittle insulation and rubbing resulted in hot and ground wires making contact.
The whole length of the wire is the same condition, fwiw.
French Import
It looks like the hot wires harness has been taped up, which in addition to your melted ground wire would make me suspect a short somewhere.
Can you remove the black tape and see what is under?
Gilles & Kathy Happiness is not having a Porsche in the garage... Happiness is having a Porsche on the road! ![]() 86 Porsche 911 Cabriolet, 2011 BMW 1200RT, 03 Saab 93 Cabriolet, 06 MB E350 Estate |
Picture illustrates the difference between a ground WIRE and a ground STRAP.
I have always believed in ground straps...they just carry more current....and if the rest of the circuit is correct...they will carry all the amps used in the system. For your case..I agree...check under the tape...also...check the ends of the red wires...are they just crimped...or crimped and soldered? When dealing with electrical problems...always go big...if in doubt...make the wire bigger...make the connector cleaner...make the connection tighter. Good luck Bob
Bob Hutson |
ROW '78 911 Targa
Just an FYI, I install a #6 instead of the #8 in the replacement engine harnesses I build.
I see a lot of very crispy main leads on old harnesses. Sent from my iPhone using Tapatalk
Dennis Euro 1978 SC Targa, SSI's, Dansk 2/1, PMO ITBs, Electric A/C Need a New Wiring Harness? PM or e-mail me. Search for "harnesses" in the classifieds. Last edited by timmy2; 01-01-2014 at 04:19 PM.. Reason: fix my error typing numbers on my phone... :) |
That wire isn't terribly thick. I'll peel the tape back and see what I can see. Timmy2, did you mean the other way around? Wouldn't the lower number be thicker?
ROW '78 911 Targa
Yes, I typed the wrong number. The Porsche cable is actually equivalent to a number 8.
I'll edit my post. Thanks. Good luck finding why that cable is/was carrying so much current. I agree with zippy_gg, probably made contact with the red cable at some time.
Another thought...have you recently given someone a jump start?
If your motor is running at the time he turns his key....the majority of power will come from YOUR alt!! (law of voltage). When jumping someone....by all means hook up and give them a 5 to 10 minute chrage if possible...but before he tries to start his engine...TURN YOURS OFF!!! This way the power to boost him will come from your battery...not your alt. Bob
Bob Hutson |
Red Line Service
We've seen this a few times before at the shop. This is typical of the results from hooking up jumper cables backwards. You're close HawgRyder. It only takes a couple of seconds or less to get this result. I'd remove the ground strap, body to trans and body to chassis and clean the connectors and surface with scotch bright, and replace your battery as well as the alternator. Also while you have it apart, we always solder the wire connectors for reliability.
Marc Bixen/Red Line Service West Los Angeles, Ca. www.redlneservice.net / info@redlineservice.net Podcast:"Marc Bixen Live" https://www.youtube.com/channel/UC4DPQbCjH3OQ_h1iUcsrFfA |
ROW '78 911 Targa
The theory of a bad boost is possible, along with the dead short of the cables.
The fact there is tape on the harness that shouldn't be there, leads me to believe the damage may be old. Peel it off and take a good look at the red cables. Sent from my iPhone using Tapatalk
All great suggestions -- will check the taped area for sure, and refit a larger diameter wire/strap. The lug on the alternator side is quite small though. May have to think about that.
If the damage was done by a bad jump, it may have been before my ownership as I don't recall ever having used this car to jump another. No telling how long the wire has been like that. Thanks again! Nathan
Coram Deo
How many wiring harnesses have you built to correct this problem? Or is this sort of damage repairable?
Dru 1980 911SC Targa Petrol Blue Metallic Cork special leather Sport Seats Limited Slip 964 Cams SSIs Rennshifter 1990 250D Opawagen 1995 E220T Sportline Familienwagen 1971 280SE Beverly... hills that is 1971 Berlina 1750 Faggio |
Functionista
I like to use GM (the horror!) ground straps from ye olde junke yarde. The ones from body to frame are short, braided, have small ends, and are plentiful. Also, consider using star washers on all grounds between body/case and ring end . Many more contact points for current to pass through.
Jeff 74 911, #3 I do not disbelieve in anything. I start from the premise that everything is true until proved false. Everything is possible. |
Red Line Service
The factory ground strap costs $6.16 pt # 911-612-233-00. Not worth fabricating, I keep one in stock.
Alternator output is self limiting, 90 amps...
Reverse install a fully charged battery or reverse jump a discharged battery and the alternator diodes will be forward biased, TONS of current flow. |
With tape removed
I unwrapped the tape and the big red wire's insulation has crumbled and fallen off.
Anyone know where this wire goes? It's got be either the alternator, the battery, or the fuse block, right?
ROW '78 911 Targa
NathanR,
The large red cable goes directly to the starter main terminal and from there directly to the battery. Looks a lot like there was apparently a dead short to the ground cable at some time. The smaller red wire goes to the 14 pin connector at the fuse panel. RDM, (Dru) Lots... these wires see extreme cycling in heat and cold etc. after 25+ years they are brittle and fragile and corroded. A number of people contact me after a motor drop and a good inspection of their engine wiring... Building SC and Mid Year Engine Harnesses
Coram Deo
If I had to guess (and I do, since I don't have any Carrera manuals), I'd say the fat one goes to the battery and the thin ones go to the fuse blocks. This end goes to the alternator
Coram Deo
What level of disassembly is necessary to install a new engine wiring harness?
