Can't remove the lower bolt on my shocks
Any tips for removing the lower bolt on my rear shocks? I've tried a breaker bar and a 3lb sledge. The top bolts came off with no problem whatsoever but the lowers are a different story. Any tips would be appreciated.
1985 Triple Black Cabriolet-ROW**Sold** 2008 Cayman S Guards Red/Black 2007 Audi A4 2.0T Red/Black |
AutoBahned
push up on the bottom with a bottle jack - use a wood or rubber spacer
when it gets to the right spot it will no doubt be fingers only to remove |
pb blaster, wait a few hours. get a 3' length of pipe to put over the breaker bar.
1982 911SC, Mocal oil cooler, Bilsteins, Carrera tensioners, backdated heat, factory short shift, Seine gate shift, turbo tie rods, pop off. 2005 Mercedes-Benz C230 kompressor sport 6-speed (daily driver) |
I like to use a 3 ton jack handle over the 1/2 in drive. Once it snaps it will come right out.
French Import
Did you remove the rear wheels or do you have the wheels on the ground?
Bentley advises to have the wheels on the ground to relieve pressure, however you can also use a jack under the trailing arm as suggested by RWebb to achieve the same effect.
Gilles & Kathy Happiness is not having a Porsche in the garage... Happiness is having a Porsche on the road! ![]() 86 Porsche 911 Cabriolet, 2011 BMW 1200RT, 03 Saab 93 Cabriolet, 06 MB E350 Estate |
1/2 inch impact wrench from Ingersol Rand, cranked up to 120psi. Never fails.
Porsche 2005 GT3, 2006 997S with bore-scoring Exotic: Ferrari F360F1 TDF, Ferrari 328 GTS Disposable Car: BMW 530xiT, 2008 Mini Cooper S Two-wheel art: Ducati 907IE, Ducati 851 |
Tagging on to Gustyones shock thread...I'm planning to remove and send out for overhaul my Bilstiens while my engine is out. Can the chassis be rolled around with the rear shocks removed?? TIA
Thor
1978 SC coupe #1834 |
Thanks for the great advice - I got them loose. Those suckers were on there tight. I used the jack handle extension on my breaker and it still took everything I had. Even after soaking in PB Blaster. I need to get an impact wrench!
AutoBahned
I always start soaking stuff in Kroil and tapping on them 1-2 weeks before I intend to pull it apart - it takes time for the penetrants to work
Brorag
right direction?
lefty loosy righty tighty.
but its backwards if your doing it from the outside. ask me how I know. |
Keepin' it Simple...
Yes
-Doug 1968 911R Clone; 11/07-?? (forever the project car )1978 911SC Midnight Blue Metallic Coupe; 7/05-11/09 (so long impact bumpers) 1973.5 911T Sepia Brown Coupe; 9/98-8/99 (went to a great home) 1973.5 911T Gulf Orange Targa; 5/97-11/02 (went back to Germany) |
BEST! Doyle
Recording Engineer, Administrator and Entrepeneur Designer of Fine Studios, Tube Amplifier Guru 1989 Porsche 911 Carrera Coupe 25th Anniversary Special Edition Middle Georgia |
Member 911 Anonymous
PBoys has the Good Year 19v batttery Impact gun, works well for the price, I use it all the time
'85 Carrera Targa Factory Marble Grey/Black * Turbo Tail * 930 Steering Wheel* Sport Seats * 17" Fuchs (r) * 3.4 * 964 Cams * 915 * LSD * Factory SS * Turbo Tie Rods * Bilsteins * Euro Pre-Muff * SW Chip on 4K DME * NGK * Sienes GSK * Targa Body Brace PCA/POC |
Thanks, DRACO! ![]() BEST! Doyle
Can't take credit Steve W, turned me on to it. Allot of Track guys use it on DE/AX events
![]() When fully charged, for the lugs, 3 clicks and it is pretty close to 96lb / sq ft torque then I finish with the torque wrench. With the included extension it is 10-15 lbs less.
Get some anti-seize and apply to the threads during reassembly. Under the car isn't the ideal environment. This will conserve the needed torque next time.
Sherwood |
For future reference.....my dad was a blacksmith, he taught me that at times, a good whack with a hammer, steel on steel but with a sacrificial piece in between so you don't bugger the head, into the fastener will help a lot, plus sometimes if you try a tightening direction (shouldn't make any progress) will break the corrosion or bond that holds the fasteners in.
I have a chunky punch that distributes the blow a fair bit (probably 1 cm face) and I give a few solid taps (no 1 kg hammers please...I use a light ball peen) works wonders. D, |
