VFR750's Avatar
CIS Injector Sleeve w/Backfire Damage??
Pulled CIS a couple of weeks ago. 121,000 miles, no issues. Looked at the system today, and I was surprised to see this damage. Car had issues with occasional backfire. Pop-off valve always saved the day. I had sealed the injector sleeves with RTV to prevent vacuum leaks.
Ever see this before? #2 cylinder sleeve is melted. All others look fantastic.
Close up
I think it must be due to backfires. #2 must have been the frequent source of the backfires. Looked down at the valve after the CIS was removed and saw no visible damage to the valve. So it's a little mystery.
I bet air was leaking past the o-ring on the injector, but was the backfire blowing past the o-ring?
Mike
'82 911SC, SSI, 22/29 tbars, 22F/22R Adj swaybars, Bilstein Sport, Elephant polybronze & monoballs, Cambermeister bar, turbo tierods, Carrera oil cooler, front brake cooling ducts, Sparco Sprint 5 & Recaro SRD PAX seat, Teamtech harness, DAS Sport rollbar.
Old 09-06-2010, 04:34 PM
do a leakdown test on that cylinder.
206 637 4071
Old 09-06-2010, 05:51 PM
NeedSpace's Avatar
My injector literately fell out of the sleeve while I was removing my CIS system from my 1976 2.7. The other 5 are quite snug. I purchased some new o-rings and a new sleeve. This is what the replaced sleeve looks like....
FYI, the chewed bit at the bottom was due to me taking it out, however, the rest that looks like a turd was how it came out.
After reading around, it looks like this was the unfortunate destruction of an intake backfire. I assume it was a vacuum leak that caused the intake backfire. I am planning on checking the other 5 cylinders and seeing they look like (for possible replacement). Is there anything else you would recommend checking while the engine is out?
Old 01-28-2012, 09:31 PM
ROW '78 911 Targa
timmy2's Avatar
Needspace, Plan to change all of them, they get brittle and you'll probably crack one or 2 when pulling them out.
Dennis
Euro 1978 SC Targa, SSI's, Dansk 2/1, PMO ITBs, Electric A/C
Need a New Wiring Harness? PM or e-mail me. Search for "harnesses" in the classifieds.
Old 01-28-2012, 11:08 PM
NeedSpace's Avatar
Timmy,
You are right. This morning, I checked the other ones, they all look like this...another purchase...Funny, when ordering I thought I should order sleeves all the way around...
Old 01-29-2012, 08:12 AM
theiceman's Avatar
remember there are two sets of o rings here. The o rings that seal the sleeve to the runner and the other that seal the injector to the sleeve. make sure you get them all.
1976 Yamaha XS360 ( Beats Walkin')
1978 911 SC Targa ( Yamaha Support Vehicle )
2006 Audi A4 2.0T (Porsche Support Vehicle )
2014 Audi A4 2.0T Technik (Audi Support Vehicle)
Old 01-29-2012, 03:15 PM
NeedSpace's Avatar
Iceman,
thanks, I'll make sure to do that. Thanks for supplying the photos.
Old 01-29-2012, 05:41 PM
