TJK TJK is offline
Bouncing Tach
I have a 1982 SC and the tach has started bouncing. Previous posts suggest voltage regulator or loose connections. What puzzles me for an electrical issue is that it only starts after 10-20 min of driving, and stops immediately upon idle. Does this fit with a dying voltage regulator? No other symptoms. How do I diagnose this given it is intermittent?
Thanks for any advice.
Old 08-03-2011, 07:02 PM
Do you still have points. When mine started to go bad the tach went nutz. New points solved it.
1972 911T/S MFI Survivor
Old 08-03-2011, 07:11 PM
RETIRED
Joe Bob's Avatar
RPMs increase voltage. A VR regulates it.....
Throw a meter on it....anything is guess work.
2012 ML350 3.0 Turbo Diesel
