Removing frozen alternator nut
Anyone ever manage to remove the fan nut using that POS pulley spanner in the tool kit?
I can't get mine off. Some have suggested sticking a screwdriver into the hole, but I don't see hoe that buys much leverage.
John Original owner '81 911SC blackmetallic coupe. Terbatrol, SSI, M+K Gen 4, SC+ cams, A/C delete, console delete, heater backdate, 7 & 8 x 16 Fuchs with polished rims, Turbo tie rods, tensioner update, Rennline engine mount bar, Mainely Custom sump plate, new top-end, corner balance. Last edited by rs6er; 09-20-2011 at 04:04 PM.. |
<insert witty title here>
If you mean the pulley tool, it should work just fine, at least it always has for me, both the older type with the 2 prongs sticking out perpendicular, and the newer kind with the holes on the inside of the pulley rim.
Before I bought the tool, I used to jam a piece of steel in one of the holes. I think that might be part of what contributed to my needing a new alternator last year. I wouldn't ever do it again. |
This is what I have. I can't get enough leverage with it. The pulley just turns it when I try to remove the nut.
John Original owner '81 911SC blackmetallic coupe. Terbatrol, SSI, M+K Gen 4, SC+ cams, A/C delete, console delete, heater backdate, 7 & 8 x 16 Fuchs with polished rims, Turbo tie rods, tensioner update, Rennline engine mount bar, Mainely Custom sump plate, new top-end, corner balance. |
have someone strong hold it with both hands. I wouldn't use the screwdriver method.
1982 911SC, Mocal oil cooler, Bilsteins, Carrera tensioners, backdated heat, factory short shift, Seine gate shift, turbo tie rods, pop off. 2005 Mercedes-Benz C230 kompressor sport 6-speed (daily driver) |
Did exactly that. No good. Nut is too tight. I put some PB Blaster on it, and will try again in the morning. If that doesn't work, I'll try some heat.
Also, can someone tell me if the bolt by the lower pulley (indicated by the red arrow) has a nut on the back or just bolts in? I can't figure out how to get to the back, and it is interfering with sliding the belt onto the alternator pulley.
Location: Manhattan Beach, California. Factory Delivery-Original owner-Retired engineer
![]() As for the nut, you may need a ratchet/socket, and some type of torque amplifier on your ratchet handle. A long pipe? Good luck, Gerry
1986 911 Targa. Per Road and Track magazine: Only in L.A.: In the window of a bar in Hermosa Beach, California. "Happy Hour prices during all car chases." Last edited by 86 911 Targa; 09-20-2011 at 05:34 PM.. |
Ours looks like this. By the way, NO HEAT!!!
1986 911 Targa. Per Road and Track magazine: Only in L.A.: In the window of a bar in Hermosa Beach, California. "Happy Hour prices during all car chases." |
Much nicer tool. I think the other came in my tool kit.
Tried the pry bar. Couldn't keep the wrench in the hole. Why no heat?
The tool should have a much longer handle on it. Get a new one, then put a pipe on it, and use a long breaker bar on the nut. Position the pipe and breaker bar close to one another where you are pushing the two together. That's usually a good position to be able apply a lot of torque.
Brett |
Some alternator shafts (my 2 do) have a hex key hole in them. Ive found that useful when doing this activity, but ive never had to resort to breaker bars on the nut, just a 1/2 inch drive ratchet has worked for me, or if i use the hex key, the appropriate size box wrench
use an impact gun it wont hurt anything taking it off
82 SC , 72 914 |
I found this additional piece to the one above in the garage. Never knew what it was for. Think I do now. It's a sleeve that fit's over the stubby spanner.
+1 on using the impact gun.
Marv Evans '69 911E |
impact gun and good tight impact socket. Make sure the gun is turning in the proper direction.
Soak it with liquid wrench or WD 40 over night first.
RGruppe #79 '73 Carrera RS spec 2.7 MFI 00 Saab 95 Aero wagon stick 01 Saab 95 Aero wagon auto 03 Boxster 90 Chevy PU Prerunner....1990 |
Need to get a 24 mm impact socket. Soaking with PB Blaster now.
I've never seen that "tool" before. It looks like a poorly made homemade substitute for the proper tool. You can buy the proper one from Pelican for I think $30. Trust me, it'll make your life a lot easier!
Current: 1987 911 cabrio Past: 1972 911t 3.0, 1986 911, 1983 944, 1999 Boxster |
muster with me at the gym
Certified Southern Dumbass! 83 911SC with 993 conversion, 98 Ford Expedition 4WD lifted beast, 98 Jeep Grand Cherokee, 01 Ford Taurus, 99 Nitro Bass boat, and a riding lawn mower
Christien. I've no doubt, and will order one from Pelican. However that would take about a week, in which time I'll be in Tibet. I need to do this yesterday. I'm wondering if the tool pictured is left over from my 356 toolkit. I must have the one from my 911 toolkit somewhere. I bought the car new.
Have located the proper tools from a friend locally. Thanks Matt.
