Removing frozen alternator nut
Anyone ever manage to remove the fan nut using that POS pulley spanner in the tool kit?
I can't get mine off. Some have suggested sticking a screwdriver into the hole, but I don't see hoe that buys much leverage. |
If you mean the pulley tool, it should work just fine, at least it always has for me, both the older type with the 2 prongs sticking out perpendicular, and the newer kind with the holes on the inside of the pulley rim.
Before I bought the tool, I used to jam a piece of steel in one of the holes. I think that might be part of what contributed to my needing a new alternator last year. I wouldn't ever do it again. |
This is what I have. I can't get enough leverage with it. The pulley just turns it when I try to remove the nut.
http://forums.pelicanparts.com/uploa...1316560210.jpg |
have someone strong hold it with both hands. I wouldn't use the screwdriver method.
Did exactly that. No good. Nut is too tight. I put some PB Blaster on it, and will try again in the morning. If that doesn't work, I'll try some heat.
Also, can someone tell me if the bolt by the lower pulley (indicated by the red arrow) has a nut on the back or just bolts in? I can't figure out how to get to the back, and it is interfering with sliding the belt onto the alternator pulley.http://forums.pelicanparts.com/uploa...1316561417.jpg
http://forums.pelicanparts.com/uploa...1316562018.jpg As for the nut, you may need a ratchet/socket, and some type of torque amplifier on your ratchet handle. A long pipe? Good luck, Gerry |
Ours looks like this. By the way, NO HEAT!!! http://forums.pelicanparts.com/uploa...1316562268.jpg |
Much nicer tool. I think the other came in my tool kit.
Tried the pry bar. Couldn't keep the wrench in the hole. Why no heat? |
The tool should have a much longer handle on it. Get a new one, then put a pipe on it, and use a long breaker bar on the nut. Position the pipe and breaker bar close to one another where you are pushing the two together. That's usually a good position to be able apply a lot of torque.
Brett |
Some alternator shafts (my 2 do) have a hex key hole in them. Ive found that useful when doing this activity, but ive never had to resort to breaker bars on the nut, just a 1/2 inch drive ratchet has worked for me, or if i use the hex key, the appropriate size box wrench
use an impact gun it wont hurt anything taking it off
I found this additional piece to the one above in the garage. Never knew what it was for. Think I do now. It's a sleeve that fit's over the stubby spanner.
http://forums.pelicanparts.com/uploa...1316572959.jpg |
+1 on using the impact gun.
impact gun and good tight impact socket. Make sure the gun is turning in the proper direction.
Soak it with liquid wrench or WD 40 over night first. |
Need to get a 24 mm impact socket. Soaking with PB Blaster now.
I've never seen that "tool" before. It looks like a poorly made homemade substitute for the proper tool. You can buy the proper one from Pelican for I think $30. Trust me, it'll make your life a lot easier!
muster with me at the gym
Christien. I've no doubt, and will order one from Pelican. However that would take about a week, in which time I'll be in Tibet. I need to do this yesterday. I'm wondering if the tool pictured is left over from my 356 toolkit. I must have the one from my 911 toolkit somewhere. I bought the car new.
Have located the proper tools from a friend locally. Thanks Matt.
| All times are GMT -8. The time now is 03:52 AM. |
