915 Transmission --- LSD
I was reading the "Swepco vs Kendall" transmission oil thread got a bit tired after a few pages.
What kept my mind wondering was the LSD.
Which model years had LSD and which didn't? Or, was LSD an option?
I have an 83 SC (US/Calif). Does my car have LSD? If it was option, where do I look to see if I have it or not.
Thanks!
1983 911 SC Coupe w Sunroof, Metallic Silver --- AKA 83 Silberpfeil
Old 06-01-2011, 11:30 AM
GrantG's Avatar
LSD is an option (look for "220" on your white sticker in the trunk with the VIN, Paint Codes, etc. to see if your car has it).
2022 GT3 Manual, 73 Carrera RS 2.9 Twin-Plug MFI Carbon Fiber Replica
Former: 18 GT3 Manual,16 Cayman GT4, 73 911S, Two 951S's, 996 C2, 993 C2, BMW 635CSi Euro, Ferrari 550 Maranello, 06 Evo IX w/ many mods
Old 06-01-2011, 11:34 AM
djcdmv's Avatar
Jack up the rear so both tires are up. Then spin one wheel and see if the other spins in the same or opposite direction. Same direction=LSD. Opposite direction=no LSD.
Dave
Black 1985 911 Carrera M491
Old 06-01-2011, 11:35 AM
PRO Motorsports
Tyson Schmidt's Avatar
Just want to add that the trans should be in neutral for this test. If it is in gear, then the other wheel will turn in the opposite direction, but with a lot of drag from the LSD clutches.
'69 911E coupe' RSR clone-in-progress (retired 911-Spec racer)
'72 911T Targa MFI 2.4E spec(Formerly "Scruffy")
2004 GT3
Old 06-01-2011, 11:41 AM
Thanks for chiming in everyone! You guys ROCK!
I'll try GrantG's easy method first, then dj's. TS --- thanks for that extra clarification.
Old 06-01-2011, 11:56 AM
Bill Verburg's Avatar
Thanks!
Most likely you don't have an lsd, as noted they were optional
another way to check is to get under the car and look at the transmission type & serial number
this is a 915/63 w/o lsd
this is a 915/73 w/ lsd, the 12 stamped between the type and serial # indicates lsd
Bill Verburg
Old 06-01-2011, 01:46 PM
ASE Master Tech - 35 yrs
larrym's Avatar
i understand the posts above, as pertain to an oem LSD - but what if a non-LSD (unmarked) trans was rebuilt - and especially if it got a Torson or viscous LSD instead of an oem unit
- i am aware that some Torson units do not behave as described above
"... I am German, and if it has no logic it's meaningless."
914 & 914-6 parts FS 03-2021 www.tinyurl.com/2pmpmv8y
911 parts FS 2022 https://tinyurl.com/911-Parts-FS-LCM
Old 07-27-2011, 04:38 PM
jibmaster1's Avatar
Car is a 85' Euro 911. OK, wanting to change my tranny fluid soon I found this thread to determine whether I had LSD or not. I jacked the rear up, in neutral (as suggested), and both wheels didn't spin at all. Well, duh I thought if the car is in 'neutral'! So, placed it in gear and noted the wheels spun opposite direction. I re-read this thread (and others) and it is ambiguous still whether I have LSD or not! Any ideas from anyone? I just want to order the correct fluid
Old 08-12-2011, 10:29 AM
GrantG's Avatar
Spinning in opposite directions means no LSD (or not working LSD anyways).
Old 08-12-2011, 10:59 AM
Porchcar guy's Avatar
Did you have the E brake off ?
15 year PCA member
1972 911 E Coupe - gone now
1987 Mazda RX-7 2+2 - still cooking
Swift DB-1 FF & Swift DB-3 F2000 -not forgotten
1979 911SC 3.0 & 2000 Camaro
Old 08-12-2011, 11:19 AM
Agfours
agfours's Avatar
Plug in your VIN into this decoder - i was going through the same question - this answered it for me.
Porsche VIN Decoder, VIN Lookup, Decode VIN
Paul
Present and accounted for: 1986 Carrera Coupe, 2021 Audi SQ8...Gone but not forgotten: 1987 Carrera Coupe, 1996 911 Carrera C4S, 1985 911 Carrera Cabriolet M491, 2011 Cayenne Turbo, 2001 Boxster S....Me: "What is your return policy?" FLAPS rep: "We really expect you to keep it..."
Old 08-12-2011, 12:45 PM
Registered knucklehead
83-911SC cab's Avatar
you were spinning by hand??
1983 911 SC Cabriolet, 1989 944 S2
1969 Chevelle SS396 w/427 Vette motor, 1970 Buick GS455
2000 BMW 528i Touring, 2005 GMC Sierra
Old 08-12-2011, 01:08 PM
Peter Zimmermann's Avatar
Engine off, handbrake off, trans in neutral, and rear wheels off the ground;
1. Turn RR wheel, if LR turns the same direction you have LSD. If the LR turns the opposite direction you do not have LSD.
Keep the Shiny Side UP!
Pete Z.
Old 08-12-2011, 01:25 PM
jibmaster1's Avatar
That's what is stumping me here. BTW, yes I had the engine off, e-brake off, jacked up rear and when I spun the wheel by hand the other wheel didn't move at all. However, when I spun the wheel while I placed the car in 1st gear (off the ground) when I spun one wheel the other spun in the opposite direction!
Old 08-12-2011, 05:54 PM
With your axles in "full droop", a CV may be binding on the othe side. In neutral, an open diff might then only turn the pinion, having less resistance, and not the other axle. In neutral, an LSD would turn both, same direction, and overcome the CV resistance if less than the LSD preload (most likely).
With an open differential and transmission in gear, turning one rear wheel would turn the other in the opposite direction, without much effort. With an LSD, the effort would be much greater, as you'll either turn the engine or overcome the LSD preload, whichever takes less force. If engine, both wheels in same direction; if LSD preload, wheels in opposite directions, but with far more effort than an open diff.
It sounds like you have a standard, open differential.
Jon B.
Vista, CA
Old 08-12-2011, 06:58 PM
