Hodgey's Avatar
Porsche Crest Spring PLate bushing replacement G50..anyone done it?
Hello.
Getting ready to do the bushing change on the rear spring plates and I'm wondering how far out the torsion bars come into the housing? From a previous thread pic (below) that I posted you can see the length of the housing for my G50, and there is a subtle change in diameter at the tip.
If the TB comes this far out, how am I going to get the spring plate off the TB and out of the vehicle? I know I have to take the blanking disc off the body to allow the tube to come out through it but still....
Does the end of the tube come off for access to the outboard end of the torsion bar or is a case of fiddling with the orientation of the tube until I can get it off and around the TB and off the car?
Thanks in advance for any pointers..
Neil
Neil
1987 Carrera, Grand Prix White, 2009 Carrera C4S, Meteor Grey Metallic
(X) [B] 2011 BMW X5[B]
'Success is not final, failure is not fatal. It is the courage to continue that counts'
Old 01-16-2011, 06:59 AM
there'a room. no need to pop off the outer disc. the rocker and the hole cover come off, of course. the torsion bar just needs to be all the way in.
206 637 4071
Old 01-16-2011, 07:35 AM
So does this end up ruining the gravel guard or whatever that black thick decal is on the side just covering this area?
Buck
'88 Coupe, '87 Cab,
'88 535i sold, '19 GLC 300 DD
Warren Hall, gone but not forgotten
Old 10-14-2011, 11:32 AM
In short, yes. If your handy you can carefully cut it out.
Old 10-14-2011, 01:15 PM
Thanks...I'm about as handy as a monkey with a ball peen hammer. Looks like I'll be buying new ones...
Buck
'88 Coupe, '87 Cab,
Old 10-14-2011, 01:38 PM
Its possible to carefully remove the torsion bar covers from the Stone guards. You can glue them together again when you are finished. Worked for me.
Old 10-14-2011, 02:51 PM
