Engine Drop Mishape
All,
I decided to drop my engine to fix some oil leaks and look for vacuum problems in the CIS.
We followed the Pelican tech article " How to Drop an Engine" The shift coupler was discounted.
When the time to lower the engine came, the engine came down faster and farther than was expected. We caught it and raised the engine and transmission quickly. We didn't hear any unusual noises or other indications that some thing went wrong.
What should I be concerned about, what should I look for or am I good to go?
Thanks,
Guy
Old 08-14-2011, 05:10 PM
Engine drop........
Originally Posted by wichitaguy57 View Post
All,
Thanks,
Guy
Guy,
If you have disconnected the 14-pin connector, electrical connections to (CDI, VR, etc.), speedometer wires, starter's big black cable, fuel lines (delivery & return), oil lines, ground cable, CV bolts, heater hoses, carbon canister hose, etc. you should be all set to go. Pull out the set screw for the transmission linkage (inside tunnel)!!!! Don't forget to disengage the accelerator pedal connection at the transmission and clutch cable.
Tony
Old 08-14-2011, 05:27 PM
Johnb911's Avatar
Check the seal on the transmission shift shaft while you are there.
It's really cheap and easy to fix while the motor is down.
If you dropped if fast with it still stuck in the tunnel there is a chance you damaged it.
First hand knowledge
JOHN
79 EURO SC
"24 Years Later - The Dream Came True"
Old 08-14-2011, 05:53 PM
fastfredracing's Avatar
The shift shaft would be the only thing I would be concerned with as long as everything else was disconnected. I have seen one bent pretty badly by an engine drop gone wrong. You are probably O.K. though. Best of luck
No left turn un stoned
Old 08-14-2011, 05:59 PM
Looks like I bent the two transmission mount seats (washers) under the transmission mounts.
The shift shaft was discounted in the tunnel and the seal appears to be OK.
Next time I'll keep the car as low as possible, discount the engine, then raise the car.
Thanks.
Old 08-18-2011, 04:35 AM
That's how I do it. I have the car at normal ride height or lower, then drop the engine slightly to the ground ( or pallet that it sits on), and raise the back of the car using an engine hoist. I attach the engine hoist to the rear engine mounts on the car with a specially made (5 minute job) lifting bar.
Rex
1975 911s and 2012 Range Rover Sport HSE
1995 BMW R1100RS, 1948 Harley FL
Old 08-18-2011, 06:11 AM
mikesride's Avatar
Originally Posted by walter_middie View Post
that's how i do it. I have the car at normal ride height or lower, then drop the engine slightly to the ground ( or pallet that it sits on), and raise the back of the car using an engine hoist. I attach the engine hoist to the rear engine mounts on the car with a specially made (5 minute job) lifting bar.
walter any pics of this operation, as i am looking for a better way of engine removal myself.
I've driven alot of crap to get here man!
Old 08-18-2011, 07:14 AM
I'll have to download pictures later today when I have access to a different computer.
Rex
Old 08-18-2011, 07:53 AM
Less brakes, more gas!
euro911sc's Avatar
If you end up needing a new shift rod pm me as I have on laying around somewhere.
Michael
'82 Euro SC 'Track Rat' 22/29 Hollows, 22/22 Tarrets, Full ERPB F/R, Rennline Tri Brace, Glass bumpers, Pro 2000's, 5 pts, blah blah blah
'13 Cayenne GTS
Old 08-18-2011, 09:24 AM
JoeyD911's Avatar
Today 01:24 PM
euro911sc
This is what i love about this forum.
Joe D
L.I. NY
82 911 SC 3.0
Swartzmetalic
Old 08-18-2011, 12:17 PM
Here are some pictures as requested of my engine drop:
Rex
Old 08-18-2011, 02:47 PM
Euro911,
Thanks and I'll let you know. It's going to be another week or so before it goes back together.
Guy
Old 08-19-2011, 10:36 AM
