DME Relay Questions
Have a few DME relay questions below. My 1993 911 (964) has a reocurring problem of a failing DM relay. The car will run fine for a few months and then start to skip. After replacing the DME relay this takes care of the problem but I'm going through around 2 relays a year. A few question below.
1. Is it normal for this relay to only last about six months? 2. Is there one brand better than another. I usually buy from our host pelican. 3. Can these be repaired ( I have a small collection of these relays now) 4. Is something else in the system causing this relay to fail? |
On the 3.2 relays, repairing is usualy just reflowing the solder connections. They seem to be manufactured poorly and the solder connections fail.
Ed 1973.5 T |
are you using one from the dealer or an off-brand?
Have you considered opening the relay to see what component is actually failing? |
