DME Relay Questions
Have a few DME relay questions below. My 1993 911 (964) has a reocurring problem of a failing DM relay. The car will run fine for a few months and then start to skip. After replacing the DME relay this takes care of the problem but I'm going through around 2 relays a year. A few question below.
1. Is it normal for this relay to only last about six months?
2. Is there one brand better than another. I usually buy from our host pelican.
3. Can these be repaired ( I have a small collection of these relays now)
4. Is something else in the system causing this relay to fail?
Old 03-16-2014, 08:52 AM
E Sully's Avatar
On the 3.2 relays, repairing is usualy just reflowing the solder connections. They seem to be manufactured poorly and the solder connections fail.
Ed
1973.5 T
Old 03-16-2014, 10:12 AM
are you using one from the dealer or an off-brand?
206 637 4071
Old 03-16-2014, 11:27 AM
wwest's Avatar
Have you considered opening the relay to see what component is actually failing?
Old 03-16-2014, 11:57 AM
