How to remove spring lock AMP connector
What is the correct method to release this type of connector ?
Old 08-17-2011, 06:24 AM
crustychief's Avatar
I pull the retainer up and unplug, then replace the retainer. When plugging together I just push them togehter.
A nose heavy airplane flies poorly, a tail heavy plane flies once.
Old 08-17-2011, 07:13 AM
CrustyChief,
I don't understand. How do you pull the retaining clip up? If I can spread the clip's open ends or unhook them using a dental tool, then I am able to remove the connector.
Please advise.
Old 08-20-2011, 05:05 PM
83 911 Production Cab #10
JJ 911SC's Avatar
Originally Posted by crustychief View Post
i pull the retainer up and unplug, then replace the retainer. When plugging together i just push them togehter.
+1...
Who Will Live... Will See
Old 08-20-2011, 06:50 PM
JJ 911SC's Avatar
Originally Posted by wichitaguy57 View Post
... If I can spread the clip's open ends or unhook them using a dental tool, then I am able to remove the connector.
Please advise.
Yes... But keep a couple fingers on the clip as you pry it off as it got a tendency to fly off and odds are that you are not going to find it back.
Old 08-20-2011, 06:54 PM
