can this be cleaned up?
While checking for an electrical gremlin I decided to remove the fuse blocks from my car. They have some serious corrosion on them but seemed to working fine.
Can these be cleaned up and how would you do it?
The front sides seem fine.
1982 SC
Old 08-17-2011, 02:42 PM
Mitch Leland's Avatar
My 2 cents would be if you don't want to replace them w/ new you could do a very light bead blast on your parts, then as long as you cover up the contact lug holes you could use a rattle can and a clear coat. Also I'm guessing you could wash the parts in baking soda and a brass brush to clean everything. Or a combination of both...
Mitch Leland
"03" 996 C2S-LS3 V8-480 HP
"84" 911 Turbo Look-Sold w/ found memories
Old 08-17-2011, 02:51 PM
masterdave's Avatar
Im a big fan of this stuff for most metal cleaning
Noxon 7® Metal Polish (6233800117) - Metal Polish & Cleaners - Ace Hardware
It will get rid of, rust, corrosion, dirt, carbon scoring, etc. etc. I use it to clean up all kinds of metal for all different purposes, including electrical stuff.
Best
Dave
David Colangelo
"Porsche Accept No Substitute"
78' 911 Targa
88' 924s
31' Ford Model A
Old 08-17-2011, 03:25 PM
dshepp806's Avatar
I'd spend time to rework what you've got,..it certainly CAN be reworked/cleaned. That is, as long as nothing's "loose"...
BEST!
Doyle
Recording Engineer, Administrator and Entrepeneur
Designer of Fine Studios, Tube Amplifier Guru
1989 Porsche 911 Carrera Coupe
25th Anniversary Special Edition
Middle Georgia
Old 08-17-2011, 03:46 PM
86 911 Targa's Avatar
Location: Manhattan Beach, California. Factory Delivery-Original owner-Retired engineer
That would be my non-toxic approach also.
1986 911 Targa.
Per Road and Track magazine:
Only in L.A.:
In the window of a bar in Hermosa Beach, California.
"Happy Hour prices during all car chases."
Old 08-17-2011, 03:49 PM
skunked's Avatar
30 minutes in evaporust and that corrosion will be gone. Keeping it from coming back is another thing.....
-Mat
78 911SC
Old 08-17-2011, 03:57 PM
DUK DUK is offline
DUK's Avatar
Good old white vinegar will do wonders.
75 911 Indian Red- RUFWAN2B 2000 Boxster
2000 & 2007 Dobies
www.stahlwerks.com Cages and preparation for your Porsche
“People who never make mistakes must get tired of doing nothing”
Bill : The origin of the orgy of Porsche
Old 08-17-2011, 06:35 PM
Detached Member
Hugh R's Avatar
Fine emery cloth will work well.
Hugh
Old 08-17-2011, 06:52 PM
Cleaning Corrosion...
Great suggestion, I would try this first... Cheap, easy, and non-evasive...
Mitch Leland
Old 08-17-2011, 06:58 PM
HawgRyder's Avatar
Send a message via ICQ to HawgRyder
Ultrasonic cleaner?
With the correct water-based fluid...would probably do a good job.
I have used one of those with Tri-chlorethelene 111 in the tank...and heated...it does a fantastic job...and dries almost instantly.
Bob
Bob Hutson
Old 08-17-2011, 08:52 PM
AutoBahned
RWebb's Avatar
vinegar
BUT if you have it all out, why not put in a modern fuse box?
Old 08-17-2011, 08:58 PM
Thanks for the suggestions. I soaked it 50/50 water vinegar and holy crap did that ever do the trick. I will post some pictures of it clean tomorrow.
As for the modern fuse box, I thought about it but this one has worked fine for 30 years and it's a lot less work than mocking up a new one. Now if I can just find my intermittent ground fault on the starter wiring I'll be happy
1982 SC
Old 08-17-2011, 09:13 PM
steely's Avatar
Steve - nice work - look fwd to the pics. One question please, is that oxidation, or did some plating come off of the screws and rear buss jumpers (in the before pics)? And if oxidation, did this do the trick, or did the bath just remove the white fuzz?
Dan
'87 Targa Carrera 3.2 - Fabspeed Cat Bypass, M&K Muffler, SW Chip
Venetian Blue
Old 08-17-2011, 10:58 PM
In maintenance phase
daniel911T's Avatar
1. Wire brush
2. A light spray of WD-40
3. Reinstall
4. Don't ever worry about it again.
Look at it this way... in all these years that's as bad as it's got. How many more years will it be before it's a problem again? (hint: many)
Drive, enjoy!
-Dan
1969 911T (Getting a 72E heart transplant)
2004 Volvo XC70
Gone, but not forgotten:1971 Bug, 1978 Bus, 1982 Westy, 1996 GTi, 2000 Audi A4 2.8, 2001 Jetta Wolfsburg 1.8T, 2002 Audi allroad 2.7T, 2010 Jetta SportWagen TDi, and a couple of short lived 914s.
Old 08-18-2011, 05:03 AM
daniel911T's Avatar
oops
Looks like I was a bit late to the party.
Glad you got it sorted out. Vinegar does do wonderful things.
-Dan
2004 Volvo XC70
Old 08-18-2011, 05:06 AM
Thanks again for all the replies. I soaked them in 50/50 vinegar and water, scrubbed them with an old toothbrush, dried them and sprayed them with a little CRC 2-26. Came out great and hopefully going back in this afternoon
1982 SC
Old 08-18-2011, 10:11 AM
It's all back in
1982 SC
Old 08-18-2011, 11:58 AM
1982 SC
Old 08-18-2011, 12:02 PM
twin plugged targa's Avatar
Nice job-I simply wired brushed and emery clothed mine - but that looks so good I guess its on my winter job list!
- PS my electrical gremlin is STILL not solved!
AKA "86ragtop" 1986 911 Carrera SOLD 11/2001
1984 Carrera 3.2 IROC RSR look
Old 08-18-2011, 01:17 PM
83 911 Production Cab #10
JJ 911SC's Avatar
It's all back in
Look great...
One more project for the winter if everything go as plan this Saturday (my Winter/Spring/Summer project)
Who Will Live... Will See
Old 08-18-2011, 04:55 PM
