Black and Blue
Kemo's Avatar
Send a message via Yahoo to Kemo
Wow...what a muffler!
I just recieved the 2 in 2 out muffler from Triad West. All i can say is "WOW"! This thing is a work of art.
I also have a pair of early heat exchangers. Im all ready to go, but I need to know what kind of oil lines to purchase to make everything work right on my SC. Anybody know the correct part number here at Pelican? Also, what year gaskets should i use between the HE's and the exhaust ports?
Kemo
1978 911 SC Non-Sunroof Coupe, two tone Primer Black and SWEPCO Blue, Currently serving as a Track Whore
1981 911 SC Sunroof Coupe, Pacific Blue Project, Future Daily Driver
Old 03-13-2002, 07:15 AM
Steve W's Avatar
Let me know what you think of your muffler. I took mine off and just replaced it with a Monty. Too much resonance for me on my 3.2 while driving. Triad should have shipped the exhaust gaskets and bolts with the muffer. The oil lines you want are the two backdated oil lines for the early heat exchangers, however some guys have been able to bend the existing lines to make it fit. Do a search for SSI oil lines if you consider that as an option.
Old 03-13-2002, 08:40 AM
where did you buy.. would like to get one also
Old 03-13-2002, 09:18 AM
Black and Blue
Kemo's Avatar
I came across the website on this board a while back,
http://www.olywa.net/triad/products/products.htm
i cant wait to get it installed. im gonna do a valve job while im at it.
I stuck a Mountain Dew can in the hole for a reference!!
Kemo
Old 03-13-2002, 09:25 AM
looks cool thanks.. how much did it set you back? $$
Old 03-13-2002, 09:29 AM
Black and Blue
Kemo's Avatar
about $350, and that number includes the cost for shipping. Best deal ive seen on 2 in 2 out. they got some cool test results on the site...
http://www.olywa.net/triad/products/CRANEY.TXT
Kemo
Old 03-13-2002, 09:31 AM
Senior Member
Superman's Avatar
Nice to see the positive reactions to the Triad system. The Triad guy is a friend.
Mocha 1978 911SC. "Coco"
Old 03-13-2002, 09:38 AM
if i can get one for my 1974 911 for $350 he will be a friend of mine also
Old 03-13-2002, 09:47 AM
tobluforu's Avatar
Damn, look at all those switches or patsch panels-that's not in your house is it . I use to get parts shipped all the time to my office and stash them in the server room also. What is it that you do
Old 03-13-2002, 10:57 AM
Black and Blue
Kemo's Avatar
Yeah, the server room is the best hiding place around here. And since I'm the only Computer Guy, there's not too many people with access to the room. Its also a great place to take a nap! (aside from the server hum)
Kemo
Old 03-13-2002, 11:20 AM
mattd's Avatar
Nice wiring job, btw! Nice and neat!
Matt Daniels
1975 911S
Old 03-13-2002, 01:44 PM
jwetering's Avatar
I'm 90% of the way through an exhaust backdate...the thermostat will be hell - trust me.
There's a very good tech article here:
mark jo's tech article on heat exchanger retrofit
But beware there are three errors that will get you:
1) Oil lines are fastened by 36 mm nuts, not 32 mm as indicated.
2) Author recommends 5/16" nuts as spacers when fitting thin flanged HX to SC studs - 5/16" nuts will actually NOT fit over these studs (not big enough)
3) My SC did not require spacing anyway - check the thickness of the flange against the length of the studs.
Regarding the modification of the stock SC oil line:
Bending the old oil line to fit is probably not going to work for you...it sure didn't for me. I was able to bend the line so that it cleared the passeneger side HX cold air inlet, but there was no way the line would clearthe drivers side HX where the line meets the case.
May the force be with you
jasper
2002 996 - arctic silver - PSS9, H&R sways,X51 oil pan, console delete, AASCO liteweight flywheel, gbox detent, RS motor mounts, 997 shifter. Great car.
past: another 2002 996 and a 1978 SC with-webers-cams-etc.
Old 03-13-2002, 09:42 PM
