Irrationally exuberant
ChrisBennet's Avatar
Front mounted oil cooler questions
Hi everyone,
I'm going to fiberglass bumpers and a nose mounted oil cooler
on my '86 911 and I'm looking for some first hand experience.
1. Can you recommend an oil cooler with -16 fittings?
2. How did you mount the cooler? Frankly this is one that I
think I need the most help on.
3. I want to retain the air conditioning in this car, are there
issues I should be aware of?
TIA,
Chris
Old 07-30-2002, 12:51 PM
marcesq's Avatar
Chris:
Check Thom's (Widebody) home page, I think he went with a front mounted cooler. At least that is what my feable memory is telling me.
Good luck.
'94 CMC Firebird Trans Am
'86 951 LS1 (C-2) Gone
'77 911 3.2 (C-1) Gone but not forgotten.
http://www.pelicanparts.com/MotorCity/marcesq1
http://www.youtube.com/user/958Fan#p/u
Old 07-30-2002, 02:43 PM
I did install a front cooler but I don't have A/C, so I don't know how that factors into the equation.
Old 07-30-2002, 02:45 PM
Bill Verburg's Avatar
This recent thread has a lot of info;
Nose mounted coolers
also
Rick Katigbak
and
Bill Verburg
Bill Verburg
Old 07-30-2002, 02:57 PM
Thanks everyone. There was some things in those posts that I had forgotten.
-Chris
Old 07-30-2002, 04:34 PM
The only thing that I can add is that I used nerf bars under the f/g caps, they will provide a modicum of impact protection in the event of a f/r collision). The Nerf bars bolt into the stock bumper mounts, using the stock euro(non hydraulic) bumper shocks The bumper shocks were switched f/r and one pair needed to be cut down(I forget which). The front nerf bar makes an ideal mounting place for an oil cooler.
Bill Verburg
Old 07-30-2002, 05:01 PM
wkbergman's Avatar
nerf bar
Bill Verburg,
in earlier message you mentioned nerf bar in context with mounting an oil cooler. Any idea where I can find such a bar?
For a 1970 911E, [the one in the Dec2010 issue of Excellence, the red Targa]
Cheers
WB
Old 12-28-2011, 01:13 PM
Originally Posted by wkbergman View Post
Bill Verburg,
Cheers
WB
here' a nicely done variation
mine goes into the bumper mounts and is a bit beefier but is otherwise similar, w/ the cooler hung below it
Bill Verburg
Old 12-28-2011, 02:00 PM
