Rotor for MSD Ignition
I read through the 3 page thread on melting rotor when used with MSD but could not follow which would be the best choice for my application.
I've got Bosch dizzy 0-231-169-008 from a 73.5 911T with a Petronix ignitor and MSD ignition and Magnecore wires.
I'd prefer a reference to a Bosch part that does not require alteration (if that exists/912 rotor?). I don't want the crap shoot with NAPA unless of course that is the only option for a 911T application.
Thanks for the help!
Kev
Old 10-16-2011, 10:02 AM
Anybody? I want to place an order here on Pelican for the correct rotor today so it will go out tomorrow if possible.
Kev
Old 10-16-2011, 02:45 PM
Two Rivers's Avatar
I think some of the old VW rotors are a solid non resisted type. Look into them , I do not remember the years. 70s ?
Old 10-16-2011, 03:07 PM
I bought the one at NAPA, works great.
Old 10-16-2011, 05:13 PM
get brass contacts, they last much longer than Alum.
Old 10-16-2011, 05:26 PM
oh yeah, I burned a rotor because "someone" "Young and dumb" put never-seize on plug threads,[no , or little ground contact]!!!!just a drop of oil! and keep stuff out of plug holes, I have vacuumed plugs before pulling.
Old 10-16-2011, 05:33 PM
I use Bosch
Bos-04038
Ronin LB
'77 911s 2.7
PMO E 8.5
SSI Monty
MSD JPI
w x6
Old 10-16-2011, 06:00 PM
Roby466's Avatar
I never had a problem with the Bosch one from PP... I kept using the stock rotor and distributor cap
1985 Black 930, K27 7006, Garretson Intercooler, Adj boost, TB: 23 - 31mm, bielstein sport shocks, ER polybronze bushings front and rear, ER monoball joints front and rear with offset camber plates, 935 X triangulated strut brace, raised spindles, racing bump steer kit
1981 Black 911sc (sold)
Old 10-16-2011, 09:41 PM
LakeCleElum's Avatar
Buy the Napa EP407. $3.99 each....Works just fine...
Bob S.
73.5 911T
1960 Mercedes 190SL
Old 10-16-2011, 10:10 PM
I see comments about using the Bosch rotor from PP but I don't even see one listed here that isn't RPM limiting for a 911T. We talking about the correct engine application?
Old 10-17-2011, 05:44 AM
pelican has sold me a bunch of them over the years
they up-graded their pn to 055-905-225B-M5014
in May 2010 I paid $6/ea
Ronin LB
'77 911s 2.7
PMO E 8.5
SSI Monty
MSD JPI
w x6
Old 10-18-2011, 11:01 PM
