To light steering
Hi,
My steering feels way to light/loose... and the car feel unstable because it changes steering directions very easy, specially in high speed. I have new bushings in the steering rod, and have no slack in the steering wheel it selves. Is this a matter of 4 wheel adjustment, camber, caster, toe? What else could be the problem, front wheels to parallel, aligned?
Remi Jakobsen 911T DP targa -71 (2.7L) Phone: +47 92844671 (Norway) |
porsher
Usually the complaint is that the steering is too heavy.
So thinking in reverse....are the tire pressures too high, are the tires old and the compound is hard, or are the tires brand new and are riding on a small contact patch. Increasing caster angle increases steering effort, i.e. move the strut top towards the rear of the car. If you mark the initial conditions, and it doesn't help you can move it back. If you do like the result you could have a shop measure the alignment and fine tune your changes. OTOH Toe way out of whack can make the car feel very unstable, which you may be describing as light steering.
86 911 Race Car, with a few 993 bits in the boiler room 79 928 Race Car 88 928 Becoming a Race Car Last edited by aston@ultrasw.c; 04-15-2011 at 10:20 AM.. |
Could be toe on the front wheels.
Typical toe (IIRC) is approx. 3/16" total toe IN. If wheels are toed out, even slightly, the car will feel unstable and "darty" and "turn-in" very quickly; autocrossers like it; me - not so much. You may want to get the alignment checked. Jerry M '78 SC |
I also had that light feeling in my steering when I was running a set of older Low End Dunlops. I upgraded to Potenza's and the steering feel improved.
A cheap way to see if this is your issue is to find another friend with a 911, and then switch wheels so you can test. This is a cheap option requiring only some time.
Christopher Mahalick 1984 911 Targa, 1974 Lotus Europa TCS 2001 BMW 530i(5spd!), Ducati 900 SS/SP 2006 Kawasaki Ninja 250, 2015 Yamaha R3 1965 Suzuki k15 Hillbilly, 1975 Suzuki GT750 |
Member 911 Anonymous
changing the bushings may have thrown the caster off, if caster is too forward (positive) then it will feel lighter and dart at speed.
'85 Carrera Targa Factory Marble Grey/Black * Turbo Tail * 930 Steering Wheel* Sport Seats * 17" Fuchs (r) * 3.4 * 964 Cams * 915 * LSD * Factory SS * Turbo Tie Rods * Bilsteins * Euro Pre-Muff * SW Chip on 4K DME * NGK * Sienes GSK * Targa Body Brace PCA/POC Last edited by DRACO A5OG; 04-14-2011 at 06:38 PM.. |
just checking but do you have a tail on your car ???? and if so do you also have a splitter in the front ???
If tail and nothing in the front you should feel awful light ...... Steve |
Have the alignment checked - specifically toe angles for the front and rear wheels.
Assuming the toe angles are within spec, then what I'd say is welcome to the the light steering (at highway speeds) of the rear engine 911. This is one of those characteristics well known to 911 drivers. |
what are your tire pressure reading when cold?
I notice lighter feel when I raise the tire pressure.
'85 Carrera Targa Factory Marble Grey/Black * Turbo Tail * 930 Steering Wheel* Sport Seats * 17" Fuchs (r) * 3.4 * 964 Cams * 915 * LSD * Factory SS * Turbo Tie Rods * Bilsteins * Euro Pre-Muff * SW Chip on 4K DME * NGK * Sienes GSK * Targa Body Brace PCA/POC |
Hope you find out what's causing it to feel "too light" so we can lighten up our "too heavy" steering that most of us seem to suffer. Cheers, Joe |
Just a side note on toe-in.....I never like quoting toe as ... "total toe is XXX inches".....because we always need to ask....where is it measured?. Outside radius of tire?.....outside radius of rim?. If stated in minutes or fraction-of-degrees.....it doesn't matter and is always "correct" as to "intent". Otherwise, you could be "off" by 100% if you meant tire diam and got rim diameter...or vice versa.
Wil Ferch 85 Carrera ( gone, but not forgotten ) |
Less brakes, more gas!
I have set my toe to 0, -2 camber, and min caster (caster must be equal on both sides!). Steering is very light. Car is very nimble. Now I have to settle the rear end... I have found that caster and toe have a very large effect on steering 'lightness'. The front end alignment is VERY easy to play with. I would sugest picking up a few of the tools (jack stands, pipe, string, tape measure, plumb bob, calculator/smart phone) and experimenting until the front feels how you like it instead of paying $80 every time you want to change something.
Don't screw with the rear... its a REAL PITA. +1 for calling toe in degrees instead of total toe distance. That is how its spec'd in the book anyway ![]() -Michael
Michael ![]() '82 Euro SC 'Track Rat' 22/29 Hollows, 22/22 Tarrets, Full ERPB F/R, Rennline Tri Brace, Glass bumpers, Pro 2000's, 5 pts, blah blah blah '13 Cayenne GTS |
What is the specs for 1971 car?
