AC Adapter Poss In Lighter Socket 70s/80s 911
RE PLUGGING IN A GPS AC Adapater .. My wrench is saying that the Porsches of the 70s/80s generally had a European Lighter Socket which is Usually not compatible with curret day AC adapters -- ever come across that issue ? ... My wrench is talking of wiring in a separate courtesy/lighter adapter into my 88 Coupe for my GPS, just to be sure I'm covered .. ie I really need a GPS for a coming roadtrip ... I am not currently stateside to check this out in person ....
Old 08-11-2013, 10:24 PM
Banned
The lighter sockets are compatible with current day A/C adapters, but the problem is that the European sockets have a slightly larger inner diameter, so the US plug is generally not tight enough to stay put. There are several "fixes" to this posted on the forum throughout the years, but what I chose to do was slip a rubber washer over my adapter plug, which then makes for a perfectly tight fit (rubber washer has a outer diameter slightly larger than the socket inner diameter). This has worked well for me for quite some time.
Old 08-11-2013, 10:33 PM
Member 911 Anonymous
DRACO A5OG's Avatar
Here you go Dr. Bulczynski 3.2 Cigarette Lighter MOD $5.99
'85 Carrera Targa
PCA/POC
Old 08-11-2013, 10:49 PM
pavegeno's Avatar
Send a message via Skype™ to pavegeno
Had the same problem for years...tried multiple sockets with varying levels of success but just got tired of the dash having the plug sticking out of it.
Finally went with a high quality adapter with a lot of nice options and hard wired it to the electrical system through the circuit that powers the courtesy lights on the door so that when I turn the car off, the unit is still powered until I open the door.
I mounted the unit to the bottom of the cruise control unit with Velcro and then used a pair of zip ties to secure it. I then mounted my Valentine One hard wire receptacle under the adapter as well.
I have a Pioneer 9500 unit that has a rear cord for my iPhone which charges the phone.
On my power adapter, I run my GPS and my voltmeter. It has two additional USB slots, one that is a 2 Amp for fast recharge and a lesser one. I have an Apple cord plugged in and coiled for my wife or daughters to charge their phones.
The voltmeter is a great unit I've been running for a long time.
Here are pictures and links:
Adaptor: Amazon.com: Multi-Use Vehicle Charger with Dual USB Ports and Dual 12 Volt Sockets - Magnadyne: Cell Phones & Accessories
Voltmeter: Equus 3721 Battery and Charging System Monitor : Amazon.com : Automotive
Enjoy,
Geno
Old 08-12-2013, 10:08 AM
AutoBahned
RWebb's Avatar
or just stick a section of mtn. bike tire tube over the plug
Old 08-12-2013, 12:38 PM
Go-Kart Mozart
JAR0023's Avatar
I simply added a strip of rubber electrical tape (it's thicker) down the length of two sides of the plug. 180* from each other 90* from the contacts. Tape has been doing it's thing for over a year now. No issues. Plug stays put. -J
86 Carrera
Every normal man must be tempted at times to spit on his hands, hoist the black flag, and begin to slit throats.
H. L. Mencken
Old 08-12-2013, 01:56 PM
nineball's Avatar
i guess i have just been lucky. both my garmin and my radar plugs work just fine in my 83.
- He gave his father "the talk"
- Once while sailing around the world he found a shortcut
- He taught a german shepard how to bark in spanish
He is.... nineball. I don't always drive sports cars, but when I do I drive a 1983 911SC Targa. Stay fast my friends.
Old 08-12-2013, 06:00 PM
Recreational User
porschenut's Avatar
I've been lucky too. I've had (3) 3.2 911s and my radar detector plug has worked securely in all of them.
Old 08-12-2013, 06:45 PM
I took Pavegeno's advice and my wrench has fitted the Adapter suggested -- Adds 2 x Normal Sockets & 2 x USB (1 x Iphone/Ipod) :
Old 09-03-2013, 12:15 PM
Look OK ?
Old 09-08-2013, 08:26 PM
AAEEEEE!
Originally Posted by pc100porsche View Post
Look OK ?
Looks good, just need to fan a face plate to cover it and look stock. Do that after your trip
Laissez les bons temps rouler
Old 09-09-2013, 05:38 AM
