Dan Morton's Avatar
how to increase fuel output with weber carbs
I have a 1970 911t 2.2 with s pistons and e cams and Weber carbs and its hesitating under hard acceleration. I am checking multiple options including measuring the fuel output which is sitting at about 0.50cc. The factory shop manual recommends up to 0.80 for s engines and 0.50 for t's. I would like to increase closer to 0.80 however I can't find any way to adjust. The zenith have a screw for adjusting but the webers dont have this.
Any ideas?
--Dan
1968 911 Coupe
1970 911T Targa
1995 993 Coupe
1997 993 Targa (sold)
Old 08-27-2011, 06:58 PM
I would rather be driving
jpnovak's Avatar
Dan, The Accel pump connects to the center shaft via a linkage. Which accelerator pump linkage do you have? There were two types. One is a straight linkage and one had a nut and threaded linkage to set the overall travel.
If adjustable you can set the linkage. Otherwise, you have to install larger jets in the accel pump squirters on top of the carb base.
Old 08-27-2011, 09:39 PM
Dan Morton's Avatar
Thanks Jamie. Mine does not have a nut for adjusting. Is there any way to update to change the linkage vs. Replacing the jets?
--Dan
1968 911 Coupe
1970 911T Targa
1995 993 Coupe
Old 08-28-2011, 07:55 AM
Dan Morton's Avatar
Also what would be the jet size for an s config?
--Dan
1968 911 Coupe
1970 911T Targa
1995 993 Coupe
Old 08-28-2011, 08:13 AM
