Paco Anton's Avatar
Send a message via Yahoo to Paco Anton
Question Window lifter not working
My driver side electrical widow lifter has stopped working (fortunately with the window raised). My first idea was that the swich was broken, so I swapped the switch with a good one but it does not work either.
Is there any other suspect besides the lifter motor?
The passenger side lifter works ok so I think it is not related to fuses/relays.
Thanks in advance!!!!
Paco Anton
83 SC Targa (Euro)
Old 09-01-2011, 09:27 AM
Wer bremst verliert
JohnJL's Avatar
Check if you are getting power and ground continuity to the pins on the relative connectors. Exhaust all the simple stuff before going to more expensive stuff like the motor.
2007 911 Turbo - Not a toy
1985 911 Cab - Wife's toy
1982 911 3.2 Indiash Rot Track Supercharged track toy
1978 911 3.0 Lichtbau toy "Gretchen"
1971 911 Targa S backroad toy
Old 09-01-2011, 10:00 AM
Mine stopped once. Turns out it was stuck. Someone pushed down on the window while I operated the switch to get it open. Put some silicon spray in the window channels and it has been fine ever since.
1986 3.2 to 3.4 conversion
Old 09-01-2011, 10:04 AM
Paco Anton's Avatar
Tried the "push down window while pressing the button" trick but does not work
Also the wires have the correct power and gound.
Time to change the motor...
Paco Anton
83 SC Targa (Euro)
Old 09-02-2011, 12:27 AM
Brorag
Brorag's Avatar
yup. mines apart with the door off, waiting on motor from Wayne. ck'd wiring, new switches, etc--not going back together till new motor in and tested.
Old 09-03-2011, 12:34 PM
