Porsche fanatic
jager911's Avatar
3.2L engine noise after track event
I have a semi-dedicated street legal track car, '74 911 with '85 3.2L. Stock engine except for bolt-on mods: K&N open filter, headers and megaphones on track and Steve Wong tune. I installed low-mileage 40k engine in 2003 and it has always run like a top. It has about 55k now.
I was running at Watkins Glen and noticed a louder than normal exhaust sound with a deeper tone, around Turn 9 and pulled into the pits immediately, i.e. only drove 2 turns at reduced speed. I parked the car and only drove it up on the trailer and into garage at home. There is a loud tick-tick-tick sound from the right bank and a minor vibration. Engine was not over-revved, no missed shifts. I did have an issue earlier in the day with stuck throttle due to bent linkage and turned off engine and coasted into pits but car ran fine after I fixed that.
Looking for opinions where to start diagnosis:
1. Valve adjustment? What is symptom of broken rocker arm?
2. Broken exhaust stud? The megaphones were not supported and do vibrate.
'56 Speedster Guards Red
'74 911 IROC- 3.2L, 22/28 tbars, 22 sways, Bilsteins, Big Reds, Seineshift, headers/M&K, slicks, 17" Fuchs, SW
'95 993 -H&R coilovers, turbo sways, GT2 wing, Fabspeed
'74 911 Targa, 87 944T, '75 911 Anniversary Edition-sold
Old 08-13-2013, 08:27 AM
Elombard's Avatar
Hopefully somthing 'relatively' simple - with the unsupported mega phones maybe it broke a header where you cant see it and its just an exh leak? Kinda sounds like what you are describing.
erik.lombard@gmail.com
1994 Lotus Esprit S4 - interesting!
84 lime green back date (LWB 911R) SOLD
RSR look hot rod, based on 75' SOLD
73 911t 3.0SC Hot rod Gulf Blue - Sold.
Old 08-13-2013, 10:46 AM
Check to make sure that your header to exhaust port nuts are tight. Happened to me in a race once.
1970 914-6 GT Track Car
1974 IROC Track Car
1987 911 Targa 3.2
2008 BMW X5
Old 08-13-2013, 11:42 AM
Porsche fanatic
jager911's Avatar
Keeping fingers crossed, I'm hoping it's that simple too. Engine's been running really strong, car keeps up with GT3s on slower infield courses. It's due for valve adjustment, so figured I'd take off megaphones, check for leaks, maybe install street M&K, then adjust valves.
I noticed the muffler gaskets have deteriorated over time so could be a leak there too but the ticking and vibration are troubling.
Obligatory picture of the patient when she's running good.
Old 08-13-2013, 11:47 AM
Before you panic, just do a valve adjustment. I would think if something bad happened, there would be a LOT of movement on your rocker arm.
I wonder if you could have done something to the exhaust?
Christopher Mahalick
1984 911 Targa, 1974 Lotus Europa TCS
2001 BMW 530i(5spd!), Ducati 900 SS/SP
2006 Kawasaki Ninja 250, 2015 Yamaha R3
1965 Suzuki k15 Hillbilly, 1975 Suzuki GT750
Old 08-13-2013, 11:52 AM
Elombard's Avatar
Hmm yah, the vibration does not fit in with the diagnosis very well.
Old 08-13-2013, 12:06 PM
Porsche fanatic
jager911's Avatar
Yep, will check that first. Haven't had time to look into anything yet.
Old 08-13-2013, 12:09 PM
He has a tick-tick-tick sound. Either an exhaust leak or a valve flung out of adjustment(best case).
Old 08-13-2013, 12:24 PM
